Author Topic: overspray removal ?  (Read 2446 times)
Offline shmed
overspray removal ?
« on: March 30 2013, 01:23:41 PM »
hi guys recently the t was painted an now i notice overspary on the inside of the rear window .
whats the best was to remove this?  without hurting the rear defroster  lines?
Re: overspray removal ?
« Reply #1 on: March 30 2013, 04:26:08 PM »
If it were me, I'd consult a body shop.
« Reply #2 on: March 30 2013, 06:09:27 PM »
Yeah, like the one that did the damage and then ask how they are going to fix their sloppy work.
Offline bryes
  • Turbo Street Stock
  • Boost 17 psi
« Reply #3 on: March 30 2013, 08:52:07 PM »
I've just scrapped  off the overspray with a razor blade and some water/windex, it works really well and won't hurt the defrost lines like a solvent might. It didn't scratch the glass either, although you might test a small area to be sure. Of course you'll have to avoid scraping off the defrost lines themselves if the ospray is on the inside. If you wan't to remove it from the actual defrost lines, then you are a complete perfectionist that is in for a much larger ordeal.
« Reply #4 on: March 30 2013, 11:16:23 PM »
Not in the car I will tell you.
AJ___
