Author Topic: My new 1986 GN T-Top build up.  (Read 25734 times)
Offline TURBOPOWERED68
  • David
Re: My new 1986 GN T-Top build up.
« Reply #15 on: March 24 2013, 06:58:21 PM »
Need to adjust/modify the fiberglass fillers
  • David
« Reply #16 on: March 24 2013, 07:04:17 PM »
the turbo has 2 (TWO) Gaskets in between it and the DP, that can't be good .
  • David
« Reply #17 on: March 24 2013, 08:00:34 PM »
I thought that it was going to be easy to get going on this car since i had one before and a full transplant on my Monte, but today i opened the hood and i was like "duhhhh"
Anyway
First things first
That big relay on the right side (driver side) gets pulled and dumped with NO other action right?
thats the one that turns on the engine cooling fan and kills the battery wile the car is off.
Offline PacecarTA
  • im not a newbie
« Reply #18 on: March 24 2013, 08:35:53 PM »
you are correct david
toss the big fan delay relay
87 GnX'd
87 GN TTop..stock as can b
  • David
« Reply #19 on: March 24 2013, 08:55:30 PM »
And tape the ends and wire-tie them out of the way?
  • David
« Reply #20 on: March 24 2013, 08:56:37 PM »
Also the turbo has a precision exhaust housing, If i remember correctly an OE garret housing would help in the spool-up department.
« Reply #21 on: March 24 2013, 09:04:59 PM »
Correct...but what convertor ya' got?
  • David
« Reply #22 on: March 24 2013, 09:59:15 PM »
good question, i am going to put plates on this thing this week and test it out a zero psi to see how it does, i know its not an accurate test but it should be ballparkish.
« Reply #23 on: March 24 2013, 10:20:53 PM »
Slide underneath it and grab some numbers off it...and maybe a pic or two. We might be able to nail it down.
  • David
« Reply #24 on: March 24 2013, 10:57:32 PM »
good idea :rock:, will do
  • David
« Reply #25 on: March 30 2013, 05:22:16 PM »
New battery is in.
The car starts right up idles good.
the "To Do" list is growing- that was expected.
  • David
« Reply #26 on: March 30 2013, 11:22:11 PM »
Before
After
that pipe is there holding the "Bent" AC line in its new (OE) position so that it doesn't crush the filter again.
« Last Edit: March 31 2013, 12:44:35 AM by TURBOPOWERED68 »
  • David
« Reply #27 on: March 31 2013, 12:46:47 AM »
on all 6 injectors, both injector clips are missing
  • David
« Reply #28 on: March 31 2013, 12:52:59 AM »
a bunch of wires at the battery, my guess is that these wires were relocated from the starter to the battery.
I like the idea but not they way it was done.
  • David
« Reply #29 on: March 31 2013, 12:57:06 AM »
Ground relocation????
the ground strap from the intake to the body is pretty chewed up and not too healthy looking.
This isn't OE on the car??
Another view
« Last Edit: March 31 2013, 07:02:41 AM by TURBOPOWERED68 »
