Author Topic: Intake Gasket  (Read 6478 times)
Offline TWIN86GNS
  • My car is almost ready!!!!
Intake Gasket
« on: February 03 2013, 01:55:18 PM »
I am going to buy an intake maniforld gasket for an engine that needs assembly.  The engine will be using Champion aluminum heads, I *believe* the gasket I want to get is the Felpro #MS96033 since the Champion heads don't have EGR ports, correct?
Or is there a newer, better gasket that I should use?
Thanks for any and all help.
Paul Beal
beal_paul@yahoo.ca
Re: Intake Gasket
« Reply #1 on: February 03 2013, 03:10:39 PM »
I'd be placing a call to Tom at Champion...but that's just me. I've got Norbs' TA heads going on my backup engine...and they're gonna be getting a call in regards to intake and head gaskets.
« Last Edit: February 03 2013, 09:51:27 PM by earlbrown »
Offline TWIN86GNS
Re: Intake Gasket
« Reply #3 on: February 16 2013, 01:36:28 AM »
Earl,
Thanks for clarifying that issue, I had it backwards.
I will try to get an MS96037.
Take care,
Paul Beal
beal_paul@yahoo.ca
Offline TWIN86GNS
Re: Intake Gasket
« Reply #4 on: March 14 2013, 09:08:16 AM »
The weather up here has kept me busy but I finally went and got my intake manifold gasket and I grabbed the MS 96037 and it looks like the one I was after.
Price wasn't as good as in the US, but then again I didn't have to use any fuel to go get it either since I got it locally here in town.  My cost was $39.95 which wasn't too bad I guess.
Paul Beal
beal_paul@yahoo.ca
