Author Topic: Corvette 4 and 3 Transmission  (Read 3215 times)
« on: February 03 2013, 09:58:54 AM »
Can someone clue me in on how these transmissions work? Is there like 3 OD's...or what's the deal?
« Last Edit: February 03 2013, 04:09:44 PM by Scoobum »
Offline PacecarTA
  • im not a newbie
Re: Corvette 4 and 3 Transmission
« Reply #1 on: February 03 2013, 09:19:32 PM »
the 4+3  is a T10 manual 4speed trans with an overdrive on the output
the overdrive is switch engaged  and can be used  on 2nd 3rd and 4th gear reducing the ratio of each gear so you have 4+3 gears
87 GnX'd
87 GN TTop..stock as can b
« Reply #2 on: February 03 2013, 10:48:46 PM »
ala Gear Vendors on an automatic
« Reply #3 on: February 04 2013, 03:51:41 PM »
Thanks guys.
Offline Tim Hensley
« Reply #4 on: May 20 2013, 03:40:18 PM »
Computer defolts to OD when key is turned on
In OD 2 3and 4 at WFO it will down shift out of OD then shift back to OD .
DLS 210-210
Champion irons
