Wrapping down pipe
Topic: Wrapping down pipe (Read 2303 times)
Shimy87
PSI: 2
Wrapping down pipe
January 30 2013, 10:45:32 AM »
Is it worth the effort to do this? Small cost, just wondered if it really has any effect on engine bay temps or if it improves turbo efficiency?
Re: Wrapping down pipe
January 30 2013, 11:01:07 AM »
waste of time altho it will reduce underhood temps a bit
Ideally, you would want the downpipe as cold as possible
sure don't want the wrapping to get oily
earlbrown
PSI: 6
January 30 2013, 11:23:47 AM »
It will make a nice wick.
Shimy87
PSI: 2
January 30 2013, 01:52:27 PM »
Thanks guys, never even thought of the fire issue
Wrapping down pipe
