Author Topic: Want to add cruise control to a non cruise control car  (Read 2464 times)
Offline 1KWIKSIX
« on: January 28 2013, 07:31:28 PM »
I'd like to add cruise control to my Buick.
Does anyone know if I can just bolt one on?
Is there wiring in place from the factory to facilitate bolting in a used cruise control unit from another GN?
I realize that I'll need a cruise stalk .
Is this do-able? I recall hearing that running the wiring thru the steering columnn is a biatch.
Any comments would be greatly appreciated.
Thanks,
Dave
Re: Want to add cruise control to a non cruise control car
« Reply #1 on: January 28 2013, 07:43:43 PM »
Might be easier to swap out the steering column from a GN with the cruise control junk already in it.
« Reply #2 on: January 29 2013, 12:08:46 AM »
I "think" the harness is there for the module to plug into...so a turn signal assembly with cruise, and the actuator under the hood should get you in the ball park
« Reply #3 on: January 30 2013, 06:04:04 PM »
It will be interesting to see- lots of guys claimed the power lock/window harnesses are universal but its not the case  per my experience.
