Author Topic: maxed 02 sensor  (Read 2872 times)
maxed 02 sensor
« on: December 09 2012, 02:18:07 PM »
I am having a strange problem. My wide band shows a lean condition and the narrow band is maxed at 1047 according to the scan tool. It stumbles and is definitely lean. BLM is pulling fuel.
I've replaced the 02 sensor with a known good one and it still has the same problem.
Re: maxed 02 sensor
« Reply #1 on: December 09 2012, 04:40:23 PM »
Are you seeing cross counts?
Re: maxed 02 sensor
« Reply #2 on: December 09 2012, 04:48:54 PM »
no stuck at zero when I tip in the wide band jumps and it levels off. reset the computer and it purred but the o2s on the scan tool stayed at 1047 so it will start pulling fuel again
Re: maxed 02 sensor
« Reply #3 on: December 09 2012, 06:05:43 PM »
So I go out to fire it up and check a few things and the battery is dead........[/size]checked to see how much draw was on the battery and its .70 amps hmm that's odd.unplug the ECU and it drops to .14 now what?
Re: maxed 02 sensor
« Reply #4 on: December 09 2012, 07:00:34 PM »
I think I figured it out there was water present in the connector at the ECU. Its drying as I type hope the ECU isn't hurt.......... .. might have to try FAST if its cooked
Re: maxed 02 sensor
« Reply #5 on: December 09 2012, 08:51:57 PM »
All new seals on the t-top, no?
Re: maxed 02 sensor
« Reply #6 on: December 09 2012, 10:11:46 PM »
yes they are new but I have had issues adjusting the windows properly so who knows.
