Author Topic: Testing for proper AE fuel  (Read 9919 times)
Offline dennisL
  • High On Boost
« on: November 09 2012, 02:22:27 PM »
I was wondering if you folks (being much smarter than me) could help me with a good way to test Acceleration Enrichment (AE).  I've changed the AE values in the chip several times and don't seem to notice a difference.  I'm referring to the AE fuel based on change in throttle position.
I understand the goal is for throttle response with no lag but beyond that is there anything I should  be looking for?
'87 GN (original owner)
'69 Camaro ZZ502
Offline PacecarTA
  • im not a newbie
Re: Testing for proper AE fuel
« Reply #1 on: November 09 2012, 08:00:37 PM »
injector duty rise above what you would see if you slowly accelerate
 the smaller the injector the less noticible changes will seem
if you were to monitor with a wideband you would be looking for a slight richening while ae is added
87 GnX'd
87 GN TTop..stock as can b
« Reply #2 on: November 09 2012, 08:09:51 PM »
I always have just set it as lean as possible with no hesitation when giving it some pedal
Offline dennisL
  • High On Boost
« Reply #3 on: November 10 2012, 09:03:53 AM »
Thanks guys.  I have 009 (42.5#) injectors and I'm tweaking the numbers after replacing Tomco green stripes.  I'll log a bunch of throttle "blips" both in and out of gear and watch the afr.
The numbers I used with the 30# injectors seemed to work well, but I didn't have a wb then.  I reduced the AE pw 15% for the larger injectors but don't see a change or dip in afr.  I probably should go back to a "fat" pw then gradually reduce it and watch the results.
'69 Camaro ZZ502
Offline PacecarTA
  • im not a newbie
« Reply #4 on: November 10 2012, 02:16:15 PM »
considering 42s are nearly 30% larger than 30# injectors , the AE PW would need to be trimmed by 30%
87 GnX'd
« Reply #5 on: November 10 2012, 05:43:30 PM »
Err... did you just say you swapped injectors without swapping chips and are now trying to tune for it?
Please clarify.
« Reply #6 on: November 11 2012, 09:55:20 AM »
He is making a new chip
Offline dennisL
  • High On Boost
« Reply #7 on: November 30 2012, 02:10:15 PM »
I got side-tracked on the AE testing but now back into it.  I'm looking at all parts of the program that deals with AE and understand the logic but I do have a question.  Before the calculated AE pulse-width is applied, it is compared to a minimum AE pw.  Can anyone think of a reason for having a minimum size pulse?
I plan to take the min check out and see what happens but thought I'd better ask the experts first. Does a fuel injector need a minimum pulse-width?
'69 Camaro ZZ502
« Reply #8 on: November 30 2012, 02:28:47 PM »
I would think the physics dictate that the inertia of the moving parts set a minimum
usable pulse width?
« Reply #9 on: November 30 2012, 03:24:14 PM »
With no pulse width you have no fuel.
AJ___
Offline dennisL
  • High On Boost
« Reply #10 on: December 01 2012, 08:53:44 AM »
Quote
[/size]I was going to say something smart here but I'll just leave it at DAAAA. :icon_eyes:
[/size]
[/size]I think Dave makes a good point on the minimum pulse needed to pull open the injector but its interesting that the program makes the pw = 00 when the calculated pw is below the min.  Almost as though a "too small" pw would cause a problem.
'69 Camaro ZZ502
« Reply #11 on: December 01 2012, 09:34:43 AM »
ok  :cheers:
AJ___
spelling error
« Last Edit: December 08 2012, 01:17:42 PM by $1987 GN$ »
Offline dennisL
  • High On Boost
« Reply #12 on: December 01 2012, 10:49:41 AM »
Thanks AJ.  I have a scope but no flow meter so won't be making that test.
The min asynchronous pw for stock injectors is set to 488 mS which seems large for a minimum.  (???)  A few mSec makes sense for a true min and adding a margin of 100 - 150mS would seem reasonable to me, but I'm only a computer geek.
I mess with this stuff for the education benefit and didn't want to break something if I made the pulse too small.  I'll leave it alone for now as it only comes into play at hot temperatures and minimal tps increase.  Each calculated AE pw is added to the previous total so the pw grows rather quickly until it reaches the max allowed.  From what I see on Power Logger, most of time it jumps right to the max pw.
'69 Camaro ZZ502
Offline dennisL
  • High On Boost
« Reply #13 on: December 01 2012, 05:00:57 PM »
I just looked at the stock min AE pulse with my glasses on and its 0.488 mS.  Big difference - that little decimal point makes.  :icon_redface:
'69 Camaro ZZ502
« Reply #14 on: December 02 2012, 12:44:15 AM »
I suspect the part to part variance becomes significant around the minimum pulse width so  we need to be careful to cut them all off for the "slowest" injectors. The semiconductors driving them are much faster but still have slew
limitations, they get hottest in that analog transition region from off to on and on to off.
