Nasty Wendy Isn't
Knowledge Base Articles, Submissions, and Comments
Penetrating Oils
Topic: Penetrating Oils (Read 9495 times)
stevemon
Turbo Street Limited
Penetrating Oils
November 09 2012, 06:23:11 AM »
FYI Penetrating Oils
Machinist's Workshop Magazine recently published some information on various penetrating oils that I found very interesting.
Some of you might appreciate this. The magazine reports they tested penetrates for break out torque on rusted nuts.
They are below, as forwarded by an ex-student and professional machinist. They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment.
*Penetrating oils ........... Average torque load to loosen*
No Oil used ..............
..... 516 pounds
WD-40 .............. ....... ... 238 pounds
PB Blaster .............. ...... 214 pounds
Liquid Wrench .............. .127 pounds
Kano Kroil .............. ...... 106 pounds
ATF*-Acetone mix........... .53 pounds
The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test.
Our local machinist group mixed up a batch and we all now use it with equally good results.
Note also that "Liquid Wrench" is almost as good as "Kroil" for about 20% of the price.
Steve from Godwin-Singer says that ATF-Acetone mix is best, but you can also use ATF and lacquer thinner in a 50-50 mix.
*ATF=Automatic Transmission Fluid
2004 Ford Ranger Edge Ext Cab
2009 Toyota Rav4 Sport 4WD, V-6
1986 GN - Sold
1989 TTA #10 - Sold
2006 Itasca Navion Motorhome
Scott87
Bone Stock
Boost Tube
Re: Penetrating Oils
November 09 2012, 08:07:51 AM »
That is quite interesting. I swear by kroil but that is what I use at work in powerhouses. Also good to confirm that pb blaster is crap (always considered it as such)
I will have to try the fifty / fifty mixture sometime.
So the mixture creeps just as good as kroil on rusted studs and nuts?
Posted From Tapatalk
November 09 2012, 08:36:01 AM »
I always have used Kroil with good results but the spray cans have a terrible nozzle just like the blaster in my experience...n
eed to mix up some ATF
Type F or DextronIII
motorhead
PSI: 4
November 09 2012, 01:50:49 PM »
I believe that ATF and brake fluid is another 50/50 mix that has been proven to be effective.
SuperSix
Administrator
PSI: 235
November 09 2012, 02:04:35 PM »
Good info, I have been using PB Blaster for years.
tb3
PSI: 2
Reply #5 on:
November 20 2012, 08:40:18 PM »
I've also always been a big fan of kroil. Its always seemed to work the best.
strange but true....
kroil is the only thing in the world I know of that I'm apperantly some kind of allergic to.
If I don't have good ventilation where I'm using it, it makes my stomach sick.
I've never thrown up, but I've felt like I was going to a few times
TWIN86GNS
My car is almost ready!!!!
Reply #6 on:
May 18 2014, 08:40:43 AM »
I recently mixed up a 50-50 mix of ATF and Acetone but hadn't used it until last weekend. My neighbour was trying to remove the winter tires and rims from his wife's car and I saw him with a sledge hammer beating on the rims. The rims had rusted to the hubs and weren't coming off so I sprayed some of the home brew penetrant on all of the studs and the centre hub and a few minutes later the rims came off without too much grief. We were both impressed.
Paul Beal
beal_paul@yahoo.ca
1986 GN #1, 11.38 @ 120.25 mph with a 1.501 60'
1986 GN #2, 13.25 @ 102.95 mph with a 2.086 60'
Top Speed
Don't Tread on Me
PSI: -2
Reply #7 on:
May 18 2014, 10:11:36 AM »
Thanks for the info!
Champion Irons w/T&D roller rockers, TA-61 turbo, 206/206 Comp Cam, 57 lb/hr Siemens Injectors, 3000 stall PTC, PTE Plenum w/RJC Power Plate, 70 mm Accufab Throttle Body, RJC 325 Megacooler, TurboTweak 5.7/ Alky Control w/M1 methanol, 23 psig on the street, Puddn' Power engine, Borla Exhaust
Penetrating Oils
