Author Topic: Power logger  (Read 3131 times)
Offline Sixpack
Power logger
« on: November 07 2012, 04:44:15 PM »
Can someone tell me what Iam doing wrong go into graphs on PL can't change graphs ur suppose to use f9 f10 f11 etc but they don't change tried in review mode nd monitor no luck checked tps sensor it's at .42 is there something Iam missing it worked before now nothing any ideas.
Re: Power logger
« Reply #1 on: November 07 2012, 04:49:19 PM »
If you mean how to you change one of the graphs from say tps to timing retard...right click on the graph and pick from the menu list that shows up
Offline dennisL
  • High On Boost
Re: Power logger
« Reply #2 on: November 08 2012, 12:06:19 PM »
I've also experienced problems in Review mode after logging data, where the program isn't responsive to control keys.  What I do now is save the file first, then load it back in, then everything works fine.  Its a pain but I never had good results trying to review the data without first saving the file.
Are there magic words we should saying or are others seeing the same?
'87 GN (original owner)
'69 Camaro ZZ502
Offline Turbodave
Re: Power logger
« Reply #3 on: November 08 2012, 02:52:45 PM »
That's normal ops.  You're supposed to save a file in order to review it.
TurboDave EWCS(SW) USN (Ret.)
Sevierville, TN
