Author Topic: Is it possible?  (Read 8078 times)
Re: Is it possible?
« Reply #15 on: October 31 2012, 09:56:46 AM »
I would not believe it was due to the chip not being seated....no way would I believe that
People are going to believe you when you say that. lol
I've seen bent pins etc . . .
AJ___
Re: Is it possible?
« Reply #16 on: October 31 2012, 10:05:57 AM »
AJ___
So you have seen bent pins cause a code 42 and no other codes?
Re: Is it possible?
« Reply #17 on: October 31 2012, 10:13:12 AM »
AJ___
My mistake; other issues.
Should have watched what thread this is Phil is all over the place.
AJ___
Re: Is it possible?
« Reply #18 on: October 31 2012, 10:49:54 AM »
I went back and edited a couple of posts from last night to indicate there is an EST feed from the module to the ecm and a by pass feed as well.  A problem with either of these two can cause a code 42 altho the most prevalent is the module itself from what I have experienced.
The diagnostic section at the bottom of this link explains the operation simply.   http://www.vortexbuicks-etc.com/code_42.htm
Re: Is it possible?
« Reply #19 on: October 31 2012, 12:11:54 PM »
Well, when the shop fixed the issue, that's what was reported back to me.  Bent pin on the stock chip.  Car was breaking up bad even after the ignition module and coil pack from NOS4GN.  Im just relaying the reality of what happened here.  Lol.  Lean exhaust popped up every now and then during that time too.
Re: Is it possible?
« Reply #20 on: October 31 2012, 12:16:18 PM »
oh, well...magic over science, I guess
