Author Topic: So, where do I start?  (Read 26759 times)
Re: So, where do I start?
« Reply #45 on: October 25 2012, 04:34:30 PM »
Your wife give you the go ahead?  :D
« Reply #46 on: October 25 2012, 04:57:00 PM »
For WOT or washing my K&N filter with her.....under garments? :D
« Reply #47 on: October 25 2012, 05:54:45 PM »
LOL
you get permission to wash it with her stuff, and you might as well take up walking on water...
« Reply #48 on: October 25 2012, 06:05:27 PM »
LOL
:rofl:
« Reply #49 on: October 25 2012, 06:55:37 PM »
priceless
« Reply #50 on: October 26 2012, 02:03:46 AM »
Now that the hot young things are out of my hottub and out of the house I can catch up on some reading...
K&N's are made out of cotton gauze. I've found the washing machine does a much better job than that goofy spritz bottle.
Just make sure not to go berserk with the oil. Since the filter is upstream of the MAF you want to coat the wires with oil. I don't think the new style LS1/LT1 filters are affected as much as the stock style though.
hahahahha, I just realized that your MAF has seen some action from two of the one's that just left!
« Reply #51 on: October 26 2012, 08:50:39 AM »
Super priceless!!!
« Reply #52 on: October 26 2012, 09:01:40 AM »
And yes, I got the MAF you sent me so I should be good. Just throw it the wash tho right? No soap or anything like that? Im going for it!
« Reply #53 on: October 26 2012, 09:58:51 AM »
put some soap in there
« Reply #54 on: October 26 2012, 12:06:20 PM »
since it's made of cotton, pretend you're washing cotton :)
« Reply #55 on: October 27 2012, 03:03:02 PM »
cool
« Reply #56 on: October 27 2012, 03:04:02 PM »
So the oil isn't mandatory or it is?
« Reply #57 on: October 27 2012, 03:38:58 PM »
yes, it is mandatory...ju st don't go nuts with it so it is sucked out of the filter and into the maf
A LIGHT coat
« Reply #58 on: October 29 2012, 10:12:30 PM »
I checked the base FP line off, and it was set at about 41 or so, so i increased it to what I believe to be 43 psi. The settings on the MAF translator were the way they should have been.  I ended up adjusting them to Steve's suggestions.  I did a few WOT pulls 1st-2nd gear.  the numbers are really consistent. Im in the process of posting a video.  I did a short WOT pull in 3rd on the highway and the O2's read at 792 with no knock.  I think im almost getting there.
« Reply #59 on: October 29 2012, 10:30:11 PM »
Tuning the buick
Fast forward to 1:19
