Author Topic: Ramchargers CFM?  (Read 16070 times)
Re: Ramchargers CFM?
« Reply #15 on: October 15 2012, 02:21:11 PM »
One of the good reasons to use a factory fan is that the shroud is usually designed to pull air thru the entire core area covered whereas a lot of the aftermarket fans are no so well designed and they tend to pull mainly thru the area covered by the blades
