Author Topic: B4BLACK welcome to Ihadav8.  (Read 6321 times)
Offline Recklessrob
« on: February 13 2006, 12:23:49 AM »
Here are some pics to start it off.
Rob
Offline 87natty
« Reply #1 on: February 13 2006, 12:52:02 AM »
I have to say your pictures were less than inspiring Rob.
As much as I love my GN, there will always be a soft spot for Q-Jets...
Offline Recklessrob
« Reply #2 on: February 13 2006, 01:04:13 AM »
Quote from: "87natty @ Mon Feb 13, 2006 12:52 am"
Thats the closest I've come to owning a pre-FI TB. I was thinking about
putting that in my Mazda at one time. I've since taken that motor apart, only
to discover that it needs a crank.
Rob
Offline Ttype83
« Reply #3 on: February 15 2006, 09:07:44 AM »
Quote from: "Recklessrob @ Mon Feb 13, 2006 1:04 am"
You can use a N/A crank for that, it's strong enough to handle the power. I've got a N/A crank with the spare engine that I plan on using for the new build.
Jim Seaton 83 T type
CarbedHotAir Slug
USAF (retired w/22yrs)
Offline Recklessrob
« Reply #4 on: February 15 2006, 12:26:22 PM »
Quote from: "Ttype83 @ Wed Feb 15, 2006 9:07 am"
No, I was going to take the crank out and put it in my '87 engine
that I'm building. (600 hp) I've heard that the standard cranks will take it, but I'm
going to gamble on it.
Rob
