Welcome to IHADAV8.com!
180 or 190 only. Where do you live?
I prefer 160 or 180, but I have doubts at the moment about the 160's qualitythe problem with the 180 is that your new chip programs the fan to come on earlier so it will run more than it needs to. I am sure Eric can fix it for you if you request it.Before you change the thermostat, put your new injectors in and the chip and see how the temperature acts.Above 180 is too hot.
remember that your fan is not coming on until 197 so there is nothing to keep the temperature below that other than the air flow thru the radiator when you are driving. So your temp is going to be higher than it will be with the new chipAlso, I often notice that the first time the thermostat opens in the morning, that it goes higher than it does the rest of the day...
