Author Topic: So I go out today to install the Denso pump that I bought in the summer  (Read 22145 times)
Re: So I go out today to install the Denso pump that I bought in the summer
« Reply #60 on: October 16 2012, 12:18:18 PM »
yeah-no help around here...got the tank back in...hoses connected...I hate those damn hoses...got to do a little wiring and I am done...done with the pump anyway...still have to fix that broken exhaust hanger and install my new wideband but at least I am done with the pump and rear springs...I hope!  :D
« Reply #61 on: October 16 2012, 01:00:42 PM »
And this is on ONE of your Buicks? You got more than one you keeping the maintence up on?
« Reply #62 on: October 16 2012, 01:32:32 PM »
I am down to two...The GN I bought new and the T I built for my son when he was in high school
Then I have the Camaro and the Challenger...
« Reply #63 on: October 16 2012, 03:26:57 PM »
Finished!!! Works like a....
Oh wait, the pump does not run....not a sound, not a drop....not a spark when I apply power directly to it...wonder why I did not try it before i reinstalled the tank...??  Dumbass!
I think I will take a couple of days off.  Have to go to the dentist tomorrow anyway...might as well do the whole masochist bit... :013:
« Reply #64 on: October 16 2012, 03:30:05 PM »
Look on the bright side...I had not put the heat shield back on or got it off the jack stands!  :D
« Reply #65 on: October 16 2012, 03:59:19 PM »
It doesn't work??? That sucks man. You have some nice cars I presume from the sound of it. You kept your car from the day you bought it till now?  Amazing.
« Reply #66 on: October 16 2012, 04:24:40 PM »
yep, it no pumpee... but it does suck!
yeah, I bought it in March of '86
« Reply #67 on: October 17 2012, 01:41:36 AM »
'teve, did you wire it correctly? If memory serves, the small post is + and the big post is - on the pump
« Reply #68 on: October 17 2012, 08:53:19 AM »
That is correct and that's the way I did it.  It does not seem to be running at all
« Reply #69 on: October 17 2012, 09:37:47 AM »
The one nagging feeling in the back of my mind is that I have it jacked up enuf to crawl under it and that maybe the little gas in the tank has uncovered the filter.
When I laid under the car and touched power to the pump lead, I could hear nothing and I did not get a spark when touching the connector...bu t?
I would like to think that no matter how silent these pumps are, I could hear it because it is fastened directly to the return tube of the pick up with no rubber between it...but?
Will get back on it tomorrow...:D
« Reply #70 on: October 17 2012, 01:32:10 PM »
hope you get it resolved.  hopefully you wont need me to come down there and fix it. Lol
« Reply #71 on: October 17 2012, 02:19:41 PM »
No, but come on, anyway...
I will fix it...just have to be sure I know if I need to buy something, or correct something, first...I will get on it tomorrow. :)
« Reply #72 on: October 17 2012, 02:23:50 PM »
Did you forget to put the fuse back in for the hotwire....... I've done that a couple times
« Reply #73 on: October 17 2012, 02:28:19 PM »
no...I ran a jumper to the back of the car so I could make the connection and listen for the pump without being drowned out by the antenna going up...also checked that for voltage...
« Reply #74 on: October 17 2012, 03:44:33 PM »
Random: maybe a bad pump....? :icon_neutral:
