Author Topic: 93 & E85 mix  (Read 4649 times)
Offline smokin-6
  • 87 T
93 & E85 mix
« on: October 02 2012, 12:33:11 PM »
Does 93 & some E85 mixed in help. I mean if someones car can run 16lbs on 93 and has no knock will some E85 mixed in allow you to run more boost? Just curious.
87 T Ported stock heads, 212/212 roller, stock block, ALKY, CAS V4, 6262, 3.5 MAF & Translator, new tranny w/ 9-11
Original owner
Re: 93 & E85 mix
« Reply #1 on: October 02 2012, 01:07:47 PM »
yes, but you may have to add some fuel in the chip depending upon how much you mix in
Re: 93 & E85 mix
« Reply #2 on: October 02 2012, 01:13:28 PM »
and make sure your injectors aren't already maxed out before adding too much corn likker
Offline alradco
Re: 93 & E85 mix
« Reply #3 on: October 03 2012, 11:56:06 PM »
I think you kind of set up yourself for a guessing game of how much boost you can run safely. By that I mean when I had my GN tuned, I knew exactly how much boost I could run on 91, 100, and C16. Especially with E85 since you need to run more fuel, just seems like you would have to really over think it.
Peter
Offline smokin-6
  • 87 T
Re: 93 & E85 mix
« Reply #4 on: October 04 2012, 03:22:37 PM »
I am not going to do the mix, I have my ALKY kit. But I've read alot of people are mixing and was curious if it helps.
Original owner
Offline TURBOPOWERED68
  • David
Re: 93 & E85 mix
« Reply #5 on: October 15 2012, 08:51:01 AM »
i am playing with approximately a 25% mix right now i just went for a 3/4 throttle blast at around 23 Psi and my Alky injection set to 3.5 i got a 10.5 O2 with a 0.0 KR reading on the Scanmaster.
My tune is ALL Fumessedcked up as i just started working on it again. Anyway it felt great, i hope as my tune gets less bad  :rofl: it should feel better. Just not sure if i will keep playing with the E85/93 mix OR just go straight to full E85. My ADD gets the best of me. :(  Not done but moving on to the next thing anyway.
Re: 93 & E85 mix
« Reply #6 on: October 15 2012, 09:55:03 AM »
It should be no problem. But E-85 is 15% gas and that doesn't vaporize/mix as good as meth or ethanol flowing in the dog house. I remember the days of fueling the 7th injector setup and the tuning/puddling issues with it.  A small mix should be great. More testing and results will only give the correct answer.
Re: 93 & E85 mix
« Reply #7 on: October 15 2012, 06:24:33 PM »
Remember on the Eth & Meth mixes: they don't "store" well. After you get your performance recipe figured out and put the car away for 2-3-4 months the damage is starting to happen. That white cakey, chalky, salty looking stuff is starting to make your life miserable. Find your favorite additive and use it.
Re: 93 & E85 mix
« Reply #8 on: October 15 2012, 07:04:53 PM »
also, I noticed that some fi hose is rated for no more than 20% ethanol...migh t need a more expensive solution
Look for mpi rated....
« Last Edit: October 15 2012, 07:24:20 PM by Steve Wood »
