Author Topic: Gonna try a diy overhaul, or two  (Read 58286 times)
Offline gusszgs
  • Limited quick brick
Re: Gonna try a diy overhaul, or two
« Reply #60 on: March 01 2015, 08:09:46 PM »
I was only considering hot tanking the case for function and making sure the circuits of the VB were free of old debris ect...
If a few cans of brake clean and compressed air will do, then I'm good.
Jim
1987 T Limited
« Reply #61 on: March 22 2015, 10:55:52 PM »
Yep, can't be TOO clean when it comes to auto trans assembly.
Also an update. Trans still shifts incredibly great. Better than any the dealers built. Every time I drive it I am amazed. I still can't believe it is going strong. I can't help but feel gun shy after all the bad builds I went through when it was new.
A gtg in Temple is coming up and if I can swing a new or at least newer pair of rear tires it shall make some passes. The ones on there now are a pair of Hoosier 255/60-15 on stock T wheels that I bought from Montgomery Ward and as many may know they went under a few years back.
Offline gusszgs
« Reply #62 on: March 25 2015, 04:07:17 PM »
I've got 255/60 MT DR's for the T and they work great plus the fit is nice. I run Hoosier QT Pros on the GS. 1.64 60ft off the foot brake
Jim
1987 T Limited
Offline bryes
  • Turbo Street Stock
  • Boost 17 psi
« Reply #63 on: March 28 2015, 09:19:50 PM »
Glad to hear that your trans is still going well TexasT, I have mine out right now and am going through it, so this thread is a nice resource!
« Reply #64 on: March 29 2015, 12:20:25 PM »
If you are going thru it yourself don't put it back together without a billet band anchor it's the part that failed on my DYI build.
Offline bryes
  • Boost 17 psi
« Reply #65 on: March 29 2015, 06:06:46 PM »
Thanks for the advice. I've started a new thread here that greater details my situation, I'll keep that billet band anchor in mind.
« Reply #66 on: March 31 2015, 09:06:48 PM »
http://www.transmissioncenter.net/200-4r.htm
They have the billet pin and the carbon band.
But as always I put in a plug for David Husek at Turbobuickperf ormance.com He will require a call but can get you anything you want or need and provide excellent service after the sale.
« Reply #67 on: March 31 2015, 09:18:29 PM »
X2 on Dave good guy.
« Reply #68 on: February 20 2025, 02:31:43 AM »
Well, I saved the text but I doubt the pix made it through. I have all the pix I'm sure but finding them again will take some effort. Hard to believe it started thirteen yrs ago. I hope everyone makes it to the facebox thing. See ya there!
