Nasty Wendy Isn't
so what are you going to do for a valve body that will provide the shifts and the clutch life of the TR valvebody?
What year is this trans? I have an idea via the VB code, but the tag cannot be read because of dirt, can you post a new pic of the tag? Or the numbers from the tag? Other than the AA coded trans, what others codes do you have? If you need tech or any parts for the rebuild, give me a call anytime.....
The transmission identification is on a plate on the right side of the case towards the tailshaft. This ID tag is usually held on by one rivet. The plate will have a two- or three-letter transmission code in large letters, and then a 13- or 14-digit identification number along the bottom:1st digit: month of production (A through M, skipping the letter "I")2nd-3rd: production day of the month 4th: shift transmission was produced (1st-3rd shift)5th: assembly plant (T: Three Rivers, MI; J: Windsor, Canada; W: Warren, MI)6th-7th: decade and year8th-9th: or 8th-10th: transmission ID code10th-13th: or 11th-14th: transmission serial number
