Author Topic: Selling a Buick and getting a 426  (Read 8470 times)
« on: September 21 2012, 11:18:32 AM »
My friend, Steve Yaklin, of Max Effort fame, recently bought a 2009 Challenger SRT8 that someone had poured a lot of money into for ported heads, big cam, programmer, etc.  It ran really well, but it was not a 426 (was a 6.1) and it did not run like his Buicks.
He had always wanted a 426 in the old days and he decided he wanted one for this car.  Only problem was that he needed more money so he finally put his Black GN up for sale to pay for all the stuff he would need to get a 426 and keep the drive train together.
The old timers will remember that he was famous for his development of alky systems on his white GN that made the magazines a few years ago.  He had alky on the black car as well and it had gone tens but had not been driven much in the last few years.
The black car was girdled, had shim head gaskets for higher compression, stock cam, and a ME tw chip with 18 degs of timing.  I think the turbo was an old 63E.
With much reluctance he put it up for sale and some guys from out of state bought it and hauled it off after a few lectures and instructions on taking it easy and learning how to drive it.  They knew nothing about Buicks.
They, of course,  went straight to the track and ran a 14.10.  They called him and asked what to do...start leaning it down with the thumbwheel.  Next run was in the 12's, the next was  in the 11's.  A couple of days ago, they went 10.58 after putting 28" tires on it.
All the above is on premium gasoline, homemade alky system, 18 degs of timing in a ME thumbwheel chip, stock cam, ported heads shifting at 5200 rpm with the car in 4th gear.
The TT SD chip is the successor to the ME.  Not as easy to dial the fuel up and down as the ME but the other features are quicker to change and no tw required.
There is a lesson in there somewhere.
Some pay a ton of money for a bunch of parts and don't run as well.  Nothing beats combination and understanding how to set the car up.
At any rate, here is a picture of his new Arrington 426 short block/engine which was installed this week.  Wish I had one!
« Last Edit: September 21 2012, 02:27:34 PM by Steve Wood »
Re: Selling a Buick and getting a 426
« Reply #1 on: September 21 2012, 11:23:01 AM »
Thats a nice looking motor! A 426 eh? And he put this in the the new SRT8?
« Reply #2 on: September 21 2012, 11:26:51 AM »
he had the 6.1 pulled out of the 2009 and used the big heads off the 6.1 on the new 426 short block
« Reply #3 on: September 21 2012, 11:39:15 AM »
My question is will it break the glass windows in some houses like the old one could?
Very nice.
AJ___
« Reply #4 on: September 21 2012, 11:52:06 AM »
This one is pretty sedate, I understand.  Maybe he just needs to run it open header
« Reply #5 on: September 21 2012, 11:59:16 AM »
Dual 3 1/2 inch out the back will work nice with some high flow mufflers. lol
But I guess it depends on the cam heads etc that are on the new ones.
I have not played with the new ones yet. That is why I asked.
AJ___
« Reply #6 on: September 21 2012, 02:05:16 PM »
It looks good but when you said 426 Hemi i had dreams of a Keith Black, huge double pumpers, loud azz kind of motor!   :rock:
« Reply #7 on: September 21 2012, 02:23:38 PM »
AJ___
I don't recall if the car has magnaflow or Flodisasters on it...The cam that was in it is actually a bit larger than the new cam that Arrington installed.  I think the new one is something like 234 degs in duration.  the old one looked to me as if it would probably make peak hp beyond the rpm potential of the car.....with the extra cubic inches, I suspect this one will be around 6500 rpm at the peak...
The gear ratios in the automatic have a big jump between third and fourth as I recall and it is tricky to get the after shift rpm to be close to the torque peak.  Again, I suspect the extra cubes will make that problem diminish
« Reply #8 on: September 21 2012, 02:26:07 PM »
I can tell you are from a prior generation than most!  Fuel injection is ever so nice for a driver these days.
The problem with the Challengers is that they weigh over 4000 lbs in spite of the light weight engine, etc.
« Reply #9 on: September 21 2012, 07:40:24 PM »
Looks like a stock hemi with a 426 sticker on it. Boooooring.
Late model engines are boring to look at in general... but, damn do they work well.
And if he really wanted to go fast he should have got a Drag Pak car.
Derek Atwill tuning and testing in Montreal. 9.90@135
« Reply #10 on: September 21 2012, 08:05:36 PM »
he wanted transportation that would go fast...
Me, I would have not put 426 anywhere on it
« Reply #11 on: September 22 2012, 09:01:13 AM »
Steve's an awesome guy - Mr. Wood you need to get him to log in over here.
Wonder what the 426 will run.
« Reply #12 on: September 22 2012, 09:27:30 AM »
Yes, he is.  One of the nicest guys I have ever known...and he has an idea every five minutes and not just about cars.  Impossible to tell him he cannot do something.  He can put a turbo and alky on just about anything.   Spraying alky on his snowmobile and turning the boost up...
I don't know what it will run.  It still has 3.06 gears in the back but the extra liter of engine seems to have really kicked up the torque.  He has bought some no hop suspension stuff but apparently you have to completely disassemble the rear end to install it so he has not got into that.  Transmission and axles are probably right at the limit now.
I think it will be in the elevens if he can hook it.  Think the damn thing weighs about 4200 lbs and that does not help.  For some reason he does not want turbos or a blower.  He ordered a Snow III kit for alky to install in case he has a little detonation.   Arrington put 11-1 pistons in it
« Reply #13 on: September 22 2012, 11:48:04 AM »
The LS2 in our TBSS comes stock with 10.9:1 compression and weighs more than a LX-chassis car. He just has to tune for knock and maximum brake torque (both fuel and spark) to overcome the short comings of being heavy. Not hard to do it just takes some time, and acceptance that running 30*+ of timing across the board went out of style with the original 426 HEMI.
« Reply #14 on: September 22 2012, 12:27:02 PM »
He know what he has to do...what he is trying to do is to run as much timing as possible without detonation...h ence the alky :)
