Author Topic: body paint ?  (Read 10793 times)
Offline shmed
body paint ?
« on: September 19 2012, 11:04:55 PM »
ok got the T running an now looking at the body have a couple dents an a couple different colored panels.
so where do i start"?
the trim an windows are removed all the seals an interior gone.
do i start sanding with 80 100 120 ??  wet or dry
i just wanna get this thing in prime before winter.
can i use rattle can primer?   does color matter ie gray, black etc?
Re: body paint ?
« Reply #1 on: September 20 2012, 09:09:52 AM »
Wow - controversial topic. Better ask your painter what he will accept.
I would use epoxy primer.
Re: body paint ?
« Reply #2 on: September 20 2012, 04:20:24 PM »
I am NOT an Automotive Painter but???
I have sprayed all kind all materials (airless, HVLP, airbrush) & if You start the paint prep then expect to pay 2x the cost for them to "fix" your work if you expect a good quality job & any form of warranty.
Just strip off the body parts & if you have bare metal lightly spot prime with something for protection & otherwise leave it alone.
I prepped my car when I was bored back in about 96-97 but I own a painting company & they still didn't accept some areas that I worked on & presented as paint ready. I only paid $600 for the spray work but it's far from being a Great finish! I don't care that it's not perfect & it still looks decent but be careful before you end up costing yourself wasted time & extra $$$ for the finished product.
If you are serious then look up some automotive painting forums (they must exist) & try to learn some basics & make a plan before you just start sanding.
You can do some of the prep but do your research & remember it's really Dirty Work when that paint dust gets on everything you own & in your eyes, ears etc.
« Last Edit: November 09 2017, 03:17:04 PM by Just a Six? »
Offline gbsean
Re: body paint ?
« Reply #3 on: September 20 2012, 04:35:53 PM »
the only primer that can be left to the elements is an epoxy or 2K primer...the primer is the most important part...the better the primer the better the paint job...you need to figure out what top coat you are going to use and start from there...Rattle cans are not an option...
Re: body paint ?
« Reply #4 on: September 20 2012, 05:16:28 PM »
hotrodders.com - body exterior subforum
http://www.hotrodders.com/forum/body-exterior/
Re: body paint ?
« Reply #5 on: November 09 2017, 08:41:33 AM »
above:
It is a good thing and must be told.
spam account "female"  I imagine
