FU$&*ING idiot Volt light.....
Pages:
2
Topic: FU$&*ING idiot Volt light..... (Read 8166 times)
daveismissing
Re: FU$&*ING idiot Volt light.....
Reply #15 on:
September 17 2012, 10:55:30 AM »
This guy will make you anything you want:
http://www.mcnallyelectronics.com/digital_boost_gauges.htm
$1987 GN$
PSI: 1
Reply #16 on:
September 17 2012, 11:23:04 AM »
If you can solder here you go. Just use some good parts and multi turn pot.
Pretty basic want.
About 5 bux of parts the box or led will cost the most.
AJ___
SuperSix
Administrator
PSI: 234
Reply #17 on:
September 17 2012, 11:28:10 AM »
What will that circuit do?
earlbrown
PSI: 6
Reply #18 on:
September 17 2012, 03:38:27 PM »
It looks like an adjustable idiot light based off of voltage.
$1987 GN$
PSI: 1
Reply #19 on:
September 17 2012, 05:29:38 PM »
Was away.
Correct Earl.
Oh adjust the variable till the led turns on when the battery voltage drops to your required level.
AJ___
Last Edit: September 17 2012, 05:47:33 PM by $1987 GN$
earlbrown
PSI: 6
Reply #20 on:
September 17 2012, 06:00:26 PM »
I've never seen a zener diode used like that in the voltage divider.
What's the benefit of doing that instead of a normal resistor on both sides? Current consumption?
$1987 GN$
PSI: 1
Reply #21 on:
September 17 2012, 06:48:49 PM »
Basically turns the op to a comparator.
AJ___
earlbrown
PSI: 6
Reply #22 on:
September 17 2012, 07:20:56 PM »
I built a differential thermostat two winters ago to control my homemade solar heating system.
After I got it built (and buggy as hell) I learned that you should use op-amps for comparator circuits instead of comparator chips. GRRRRRRRR
Teaching myself electronics is more harder than learning how to keep a keep a factory ECM in tune!
Reply #23 on:
September 17 2012, 07:28:15 PM »
If you would try tuning in F sharp instead of D flat, that ecm would come around in no time
earlbrown
PSI: 6
Reply #24 on:
September 17 2012, 09:12:38 PM »
I haven't taught myself about cheeses yet. I can't tell a sharp from a flat from a chedder
daveismissing
Reply #25 on:
September 17 2012, 10:53:43 PM »
Well, the comparator is faster and cleaner, it just has open collector aka single ended outputs. If you buffer the signal it works ok.
daveismissing
Reply #26 on:
September 17 2012, 11:00:17 PM »
http://tinyurl.com/cheezeswow
Pages:
2
