Nasty Wendy Isn't
Brake cleaner is a gift from heaven.
Quote from: SuperSix on August 30 2012, 10:00:20 PMBrake cleaner is a gift from heaven.Chlorinated or non chlorinated?AJ___
I use plain ole spit on my injector orings (oddly enough the same lube I use in place of astroglide/analeze)Do normal people pull the radiator when doing a timing chain? The intercooler is as far as I go when I'm doing one.
this is a bit different, he has a brand new radiator...why stick it in the car and chance getting a wrench bounced off it? hell, I don't care, put it in....
I would listen to Steve as he claimed to said "don't put the radiator in if the guy is going to have to take it out again to do the timing chain" To many things happen, a slip of a tool, a mistake, and then shit happens, and you're playing peek a poo.
it does not have to be removed to get to the cover...put it in if you want to
Quote from: Steve Wood on August 31 2012, 12:28:50 PMit does not have to be removed to get to the cover...put it in if you want to Now I'm confused, I though Phil said he was going to put the radiator back in, where as Steve said don't put it back if the guy is going to do the timing work. Now Steve said it does not have to be removed to get to the cover...put it in if you want toI'm sooo confused Is radiator in the car now or not?
LOL////he had a semi valid reason to put it in...it's only two minutes to put it in...but, when he starts trying to figure out how to connect the lines up to a screwed up radiator, it will drag into two weeks...
