Author Topic: Fuel line O-rings  (Read 6806 times)
Offline dennisL
  • High On Boost
Fuel line O-rings
« on: August 28 2012, 10:54:35 AM »
While changing my fuel filter I noticed the o-rings on the hard lines looked funky.  They are the original ones from 1987.  I left them alone and put in the new filter, but now I'm not sure that was the right thing to do.  Its not leaking, but I can only check with static fuel pressure.  At 60 lbs it might be a different story.
So my questions are:
1- How important are these two o-rings?
2- If they are critical, where can I get new ones?
3- The new filter is a Fram G3727 that I've had on the shelf for at least 5 years.  Is there a better filter that I should be using?
Thanks,
Dennis
'87 GN (original owner)
'69 Camaro ZZ502
Re: Fuel line O-rings
« Reply #1 on: August 28 2012, 11:34:17 AM »
believe these are the right ones....
http://www.summitracing.com/parts/NAL-22514722/
« Reply #2 on: August 28 2012, 11:52:49 AM »
Replace the orings while you can.. They are generic, any parts house will have some.
$6.65 shipped with Amazon Prime.
http://www.amazon.com/Delphi-FH10108-Injection-Nozzle-O-Ring/dp/B001O02KOY/ref=sr_1_2?s=automotive&ie=UTF8&qid=1346169136&sr=1-2&keywords=Fuel+Injector+O-rings
« Reply #3 on: August 28 2012, 11:53:43 AM »
I prefer AC Delco filters, personally.
http://www.amazon.com/ACDelco-GF652-Fuel-Filter/dp/B000C9SR90/ref=au_pf_pfg_s?ie=UTF8&Make=Buick|45&Model=Regal|392&Year=1987|1987&carId=002&n=15684181&s=automotive&vehicleType=5
Offline PacecarTA
  • im not a newbie
« Reply #4 on: August 28 2012, 12:01:46 PM »
use your search engine using the 27478 number  to locate some locally
Fuel Rail O-Ring Kit             BorgWarner 27478 (also under neihoff brand )    2.44
it has  rings for the rail /filter and also for the return line at regulator
http://www.amazon.com/Borg-Warner-27478-Fuel-O-Ring/dp/B000BZCG2O
87 GnX'd
87 GN TTop..stock as can b
« Reply #6 on: August 28 2012, 01:15:19 PM »
Why are those called "injector" with two size o-rings while these are only one size?
Dave even that pic looks like 2 top rows are 8 Injector/Regulator orings while the bottom 2 rows look they belong on the metal tubing for Feed/Return/Pump lines.
Just a guess but I have a few sets here from here & there over the years & the injector ones are always fatter. Altho maybe I'm seeing the pic funny???
« Reply #7 on: August 28 2012, 02:12:41 PM »
I gave him the number for the fuel filter o rings.
Then he got numbers for injectors and numbers for the fuel rail.....good post because everything seems to be covered
Offline dennisL
  • High On Boost
« Reply #8 on: August 28 2012, 03:36:39 PM »
Thanks, guys. I can get the o-rings from Napa (2-18416 (Echlin Fuel System - 1 of each size, supply & return lines) or better yet since I only need the supply line size, I think I'll order a few from Summit (thanks Steve)
By the way, if you tell Amazon its for a 1987 Buick Regal while at
Quote
this message appears "This product does not fit your 1987 Buick Regal". (??)
I changed the fuel filter because it had been on there a long time, and was hoping that would solve my problem of the regulator not increasing pressure with boost.  Well, it didn't.  So its either the Accufab regulator or the Walbro fuel pump thats bad.  The regulator is older so I just ordered a rebuild kit for it.
In the meantime, I'll get some new fuel line rubbers because I respect your opinion and apparently, you guys always practice "safe fuel". :icon_lol:
'69 Camaro ZZ502
« Reply #9 on: August 28 2012, 04:44:11 PM »
I got that same message when I clicked on that link too... :)
« Reply #10 on: August 28 2012, 05:11:58 PM »
« Reply #11 on: August 28 2012, 05:19:20 PM »
If I linked wrong this is the one I meant:
http://www.amazon.com/ACDelco-217-3102-Service-Fuel-Injector/dp/B0031IDXBQ/ref=pd_sim_sbs_auto_4
I get this:
Quote
This product fits your 1987 Buick Regal
Engine: 3.8L V6 Gas OHV Distributorles s Turbocharged SFI Electronic FI MFI
Trim: Grand National
Fitment Notes: Injector O-Ring Or Seal, SEAL KIT - 15 X 3.6MM, 7.8 HOLE - INCLS (12) 05235032 SEALS - BLUE O-RING CAN BE USED TO SERVICE BLACK/BROWN O-RING
