Author Topic: Beautiful GN restoration.  (Read 9278 times)
« on: August 26 2012, 04:40:25 PM »
I posted this in Tech - because there's over 1100 photos at this link - great, visual reference material.
I want to contact the owner and see if they will send the pics zipped to me...
http://www.americanrestomods.com/1987-buick-grand-national-restoration/
Re: Beautiful GN restoration.
« Reply #1 on: August 27 2012, 08:33:55 PM »
Beautiful restoration. But stock is sooooo boring.
« Reply #2 on: August 27 2012, 09:31:37 PM »
I like it as an archive. Amazing the work that went into that car.
« Reply #3 on: August 27 2012, 09:34:12 PM »
When was you looked archived old porn? Sure it was hot back in the day, but take today's spiced up porn... betcha can't look away. ;)
« Reply #4 on: August 27 2012, 09:34:50 PM »
Hahaha... Touche
« Reply #5 on: August 28 2012, 12:59:11 AM »
I sometimes go back to vintage porn. Sometimes it's nice. ESP when some good looking star get's all shot out with fake tits and stupid ink :)
I was skimming the thumbnails thinking how relaxing it much have been to just take a car apart, paint it, then put it back together...   No finding out bolt on parts don't bolt on, never have to talk 5 hours worth of work apart to do an "unnecessary" 30 second mod...
Then I noticed this (along with the Alpine FM modulator changer)
Is this to offset driver weight, inject the intake stream with free hydrogen gas from the battery, or is the "MAF heat conducting device" a top secret power secret?
Offline Scott87
  • Boost Tube
« Reply #6 on: August 28 2012, 06:09:55 AM »
Weird photo..  That looks like a frugal build?
I could imagine the thought process.  Don't have what I need but have this chromed 180 kicking around..
Posted From Tapatalk
« Reply #7 on: August 29 2012, 12:00:48 PM »
I saw that also, cook the MAF, and good luck adjusting the wastegate rod at the track
« Reply #8 on: August 29 2012, 12:44:35 PM »
What is that redesign making room for? Maybe if the battery was trunk mounted - and the MAF was further away from the turbo.
I wonder of there's harmonics issues having the MAF bolted to a turbo like that.
« Reply #9 on: August 29 2012, 02:24:11 PM »
I guess it was worth it to extend the wiring harness to show off the charcoal cannister.
wait, I recall seeing some pics of the stock airbox being painted. Someone went through all the trouble to prep and paint the stock setup and then ditched it with the kit from ricers-R-us???
Offline gbsean
« Reply #10 on: August 29 2012, 08:24:47 PM »
that is a ton of labor and $$$$ in that
« Reply #11 on: August 29 2012, 08:41:11 PM »
That's what I thought. Amazing attention and expense.
« Reply #12 on: August 30 2012, 08:08:01 AM »
There is just something really funny about heatsoaking the IAT and sucking in hot air off that side of the engine. No wait... not funny, sad. Yes. That's the word I was looking for: sad.
« Reply #13 on: August 31 2012, 10:28:45 AM »
Offline firebird_1252
  • PSI: -1
« Reply #14 on: September 02 2012, 09:29:31 AM »
i talked to them on fb the other day. i'm highly considering sending mine to them.
87 GN- :D
