Author Topic: 87GN Last Time Under the Knife,FL  (Read 38205 times)
Offline I Love Factory ECMs
  • GIMP
  • PSI: -16
Re: 87GN Last Time Under the Knife,FL
« Reply #30 on: August 22 2012, 12:26:02 PM »
Looking very nice, congrats. Body shop a friend?
AJ___
Nope found him online, I visited over 20 neer by shops an put other est. out on-line,This was the only guy that could produce an Warranty the finish product i was after,No runs,no sanding marks,no debris trash in paint,all panel match in color,etc,etc...He does allow you to help out anyway you can to save some money.This is an open check build pretty much till it's completed.
Enjoy!
  • GIMP
  • PSI: -16
« Reply #31 on: August 22 2012, 12:27:54 PM »
Very nice build.  Thanks for sharing.  The heat dispersent paint used on the radiator, any chance you remember the brand / type ?
Posted From Tapatalk
He told me but i forget the name, right at the end the build, (Hopfully in less 2 months)I'll post All the info on the build including the paint brands an processes.
Enjoy!
« Reply #32 on: August 22 2012, 06:14:16 PM »
If it matters. The color/paint used to increase radiation doesn't do anything.
Now there is a paint that is designed to absorb longwave radiation and convert it to heat.....
http://www.builditsolar.com/Experimental/PaintAbsorbancy/GlossvsFlat.htm
It performs almost as well as plain ole flat black :)
« Reply #33 on: August 23 2012, 12:12:40 AM »
Yep
Bruce the science guy:
actually, there is a lot of reason not to paint it black
it should be running at around 350K. That makes its thermal emission
peak at about 8.4 microns.
this is mid infrared... so to enhance heat loss, it's fine to paint it
with somethng that has high emmisivity in the mid infra-red. You can
be fairly sure that black paint is not such a material. Neither is
anodising but sandblasting may work well.
  • GIMP
  • PSI: -16
« Reply #34 on: August 27 2012, 02:41:33 PM »
8-27-12, The rear's being mocked for the new rear custom built Q1'a, Front's are in an Done!! Battery's going in the spare tire holder then i'll get a trunk kit to hide it. Now i'm debating the seat upholstery. Go Leather stock color's or stay stock colored cloth...it's $200 difference,but with the leather kit you get the rear side an front side door panel material too...It's almost ready for the first fire-up!!! Opps,totaly forgot to ask about heat dispersant paint,I'll get the name an brand next trip ;^)
« Reply #35 on: August 27 2012, 02:44:18 PM »
Very nice, thanks for the update!
  • GIMP
  • PSI: -16
« Reply #36 on: September 06 2012, 01:49:06 PM »
9-5-12 ,The Rear's been mocked an being assembled an checked for straightness,The battery box is in (adding a fake one in front to hide relays an the Alky pump). Once it's rolling again an battery's in it it's time to Power it up an debug anything found. It's about that time to Call goddess Holly for Cal....The Xfi's been 2.0 updated an traction control installed. To make sure i dont screw the pouch i'm have Cal Hartline go over the car before first fire,then hopefully fire it an go for some test drives, I can't dyno it yet till i break in the brand new gear's in the rear, so'll we'll just do drivability test an knowing me do one full throttle hwy run at 22psi.
« Reply #37 on: September 06 2012, 02:02:39 PM »
Excellent - love the updates!
Offline TURBOPOWERED68
  • David
« Reply #38 on: September 09 2012, 07:59:45 AM »
looks great dude :rock:
  • GIMP
  • PSI: -16
« Reply #39 on: September 11 2012, 01:57:21 PM »
I had to do something or else you seen the huge RJC Racing logo through the grill...;^)
The Paint is from http://www.techlinecoatings.com/
It's called Cilgen Thermal Dispersent paint. (After reading about it, Now you can't Spray Graffiti on my intercooler,Great for trips to the "Hood" ...lol)
  • GIMP
  • PSI: -16
« Reply #40 on: September 11 2012, 01:58:04 PM »
Yep
  • GIMP
  • PSI: -16
« Reply #41 on: September 11 2012, 02:01:42 PM »
  • GIMP
  • PSI: -16
« Reply #42 on: September 12 2012, 10:06:49 PM »
9-11-12 , Car's in same shape was last update,(no photos this trip) Bob had family business to attend. The Rears being picked up today,It's all assembled an ready for paint!! Ride height get's set an new steel rear fuel lines ran an Back's done!! I called Cal Hartline an have an appointment with him next Tues. at Noon. We'er going to go over the whole car an check all the wiring's good (XFI,Traction control,Boost Sol.,Alky kit, etc,etc,) After all that if it's good to go, We Fire It!!! I'm so ready to have my car back!!!
Enjoy!
  • GIMP
  • PSI: -16
« Reply #43 on: September 17 2012, 01:23:14 PM »
9-17-12, Cars so's close to being finished,i can smell 93 an methanol..Rear's in, New custom Drive shaft being made today. Battery box is in (An the fake one with alky pump an other relay's hiden under it,;^),I know GN's didn't come with top terminals,but thats what they got,i can chagne it later ) Cal Hartline visits tomorrow an we go over the wiring an see all what's left before the virgin fire-up (for the 6th time in 10 years..)
  • GIMP
  • PSI: -16
« Reply #44 on: September 17 2012, 01:33:16 PM »
(I had added the thread to the Central Fl GN/ttype club because i'm paying member of them,I've known the owners since the 80's,But your right, It's a Technical build in a Half) 8^)
