Author Topic: Adding a new fabrication section  (Read 18835 times)
Offline gnonyx
« on: August 20 2012, 01:21:17 PM »
 :icon_fU: Hi, Is it possible to add a new fabrication section so others can display their modification work while others can duplicate, add, and modify their system.
 :rock:
Re: Adding a new fabrication section
« Reply #1 on: August 20 2012, 01:45:17 PM »
Done!
Thanks for the suggestion.
 :powersix: :powersix: :powersix: :powersix: :powersix:
http://www.ihadav8.com/forum/index.php?board=28.0
