Author Topic: 13.41  (Read 4866 times)
Offline Sixpack
« on: August 17 2012, 04:33:07 PM »
17psi boost no mile an hour 98.69 1.859 60ft stupid me didn't save the run on logger lost info wot 21 deg 1-2 22 deg no knk retard. Gonna lean it out at the hit  was at 130 gonna try 125 there something I'm missing
Re: 13.41
« Reply #1 on: August 17 2012, 04:47:21 PM »
Tires?
Offline Sixpack
Re: 13.41
« Reply #2 on: August 17 2012, 04:56:21 PM »
26 inch mickeys 15lbs track is about 127 degrees f still hooks pretty good no wheel spin
Re: 13.41
« Reply #3 on: August 17 2012, 05:10:04 PM »
 You are missing the info you need to know if it can be leaned out safely....been a big help if you had recorded the run
Offline Sixpack
Re: 13.41
« Reply #4 on: August 17 2012, 06:02:36 PM »
Yea I know still a newbie at the plc
Re: 13.41
« Reply #5 on: August 17 2012, 06:59:59 PM »
most of us have done it....:)
Look at your time slip...see how many miles per hour it gained in the last half of the run...I would guess it, being more or less stock, should have picked up about 22 mph after the first 1/8"
It seems to be a bit slow as I would have guessed about 102 mph for that time...was it lean, was it rich, or are the valve springs tired?  I don't know
Offline Sixpack
Re: 13.41
« Reply #6 on: August 18 2012, 12:47:30 AM »
Maybe alittle rich new valve springs may need to lean out some one run tomorrow befor eliminations did some changes c waht happens
Re: 13.41
« Reply #7 on: August 18 2012, 09:45:23 AM »
if it is lean and the timing is being pulled in response to detonation, it will slow down as well...I hope to heck it is not lean because you may have other problems if you lean it down
start recording before your next pass :D
Offline Sixpack
Re: 13.41
« Reply #8 on: August 18 2012, 10:26:12 AM »
Here is what I have on the blm boxes the lower ones that tt says to adjust
130. 125. 130.  130  I was able to change them I guess the plc came updated?
This after I changed them the first run
130.  129. 130.  130.  Won't macke a pass till about 9am PDT here in Cali at Pomona raceway
