Author Topic: 84 GN no A/C since.... 87?  (Read 34276 times)
Re: 84 GN no A/C since.... 87?
« Reply #30 on: August 21 2012, 07:47:55 PM »
Thanks, for the warning, I emailed the seller and cancelled the order.... I owe you a beer, if I ever meet you!
Now just hope there's no problem with the ebay cancellation.
So does anyone know who or where I can get a set of lines purchased or special made? I'll keep looking...
Chuck
If he gives you any guff - make sure him, and eBay/Paypal know his page is incorrect, it's not your fault.
« Reply #31 on: August 21 2012, 08:00:23 PM »
ask at your parts store.  Most decent sized towns have a place that makes hoses
Offline 84 BuickGNYorkPA
  • PA Certified Machinist
11.17@127.78
« Reply #33 on: August 21 2012, 08:27:03 PM »
There was a guy here but he's out of business, I'll keep asking around...
ding, ding, ding..
http://www.autorepairpa.com/air-conditioning.html
Chuck
« Last Edit: August 21 2012, 08:58:09 PM by 84 BuickGNYorkPA »
11.17@127.78
« Reply #34 on: August 22 2012, 08:41:30 AM »
Like I said Chuck, if you need me just ask. My local NAPA makes up hoses from your original fittings. I did Dave's AC last year and he was happy with the results.
« Reply #35 on: August 22 2012, 09:59:45 AM »
we all get along better with a little help from our friends :)
« Reply #36 on: August 22 2012, 07:36:51 PM »
Thanks Gary, I'll let you know.
The ebay joint shipped the wrong hoses today  :068: they will go right back, I had sent them 2 stop request emails and they still sent them....
11.17@127.78
« Reply #37 on: August 22 2012, 10:38:21 PM »
« Reply #38 on: August 23 2012, 09:28:05 AM »
Found these  http://www.gbodyparts.com/product_info.php?products_id=401&osCsid=34df05d50eef8e1eeb451a8aacb85c95
Like I posted on TB.kom - Unless you are going for a show car look, it's a lot cheaper to get your current lines rebuilt.
Also - even if the ones that hack are selling are "new" - how old are the rubber lines? 20+ years?
« Reply #39 on: August 23 2012, 10:13:31 AM »
Also...if using 134a, a new barrier hose works better than the original hoses for our cars.  Altho, a used hose for our cars should work as well because it should be pretty much plugged up from the old oil as I understand it.
« Reply #40 on: August 23 2012, 09:39:25 PM »
Update: Ebay vendor was out of the office yesterday, he notified the carrier to return the hoses and has agreed to give me a 100% refund, once they get back to his business.
Compressor is off, lines are at the repair shop, new compressor showed up today, was thinking may be easier to put lines on compressor before installing on car... repair shop said they should have them done by tomorrow.. $65- $80 somewhere in that price range. He also mentioned that the old hose and the 134A are not a good combination... .. kinda what Steve was saying, I believe.
Chuck
11.17@127.78
« Reply #41 on: August 23 2012, 11:25:07 PM »
Do you have all new orings, a new orifice tube and R12 > r134a adapters?
« Reply #42 on: August 24 2012, 05:58:45 AM »
Yes I do...
So now I already put 2 oz of oil in the accumilator, I have to check and see if there is any oil in the new compressor, it came from advanced auto parts. I doubt that it does, if it doesn't do I just put the oil in where the tube manifold hooks up?
Chuck
« Last Edit: August 24 2012, 06:02:56 AM by 84 BuickGNYorkPA »
11.17@127.78
« Reply #43 on: August 24 2012, 08:58:24 AM »
If there is any oil in the new compressor, dump it out through the line ports and measure it. The whole system takes 6 oz., you have 2 in the acc., so dump no more than 4 oz in the line ports as you slowly rotate the compressor pulley. Also, now would be a great time to put dye in. I use the small quarter oz. container (part no. 765-2665) from NAPA.
« Reply #44 on: August 24 2012, 08:59:25 AM »
I doubt it will come with oil.  I am not exactly sure of the amounts, but it should be split up between the compressor and drier - some recommend putting a portion in the condenser too.
CharlieF said to make sure that after you add the oil to to compressor, while on the bench, rotate the compressor ~10-20 times to distribute the oil through the inside of the compressor.
