I'll take a guess at it? I would think that by the time the pump is told to turn on & the alchy is actually in the motor would be maybe 1 second. (Just a number) Now when you floor it going from 8lbs to 17lbs probably only takes a 1 second. Once it's spooling the boost shoots up pretty quick.So the 1 second for each should meet together more or less??With the progressive I ASSume it starts spraying slower until it's told to spray Max Flow?Maybe that accounts for the 1 second as well??Again, just a guess?? Now let the pro's answer & see how far off I am??
Even a broken clock reads right twice a day!! Thanks! PS: You can open Razors control box & adjust the start point but he reccomends the average guy should just leave it how he sets them at about the 8lb mark.
Eric usually pulls a little fuel out of the chip when he burns an alky chip along with some other things. Just order a regular chip. You can vary timing and wot fuel thru the programming part of the chip.So, are you going to tell us what you fixed so the next guy can benefit from your experience?
Quote from: Steve Wood on August 14 2012, 01:41:24 PMEric usually pulls a little fuel out of the chip when he burns an alky chip along with some other things. Just order a regular chip. You can vary timing and wot fuel thru the programming part of the chip.So, are you going to tell us what you fixed so the next guy can benefit from your experience?Absolutely!! Turned out to be an intermittent connection going into the P7(white wire) as you guys had suggested. I cut the white wire on both connectors and just mated them with a spade end and a female end(kinda like a plug). Brake lights right up!
