Author Topic: Brass fitting sealant for alcohol tanks?  (Read 4814 times)
Offline gordyzx9r
  • The Sultan of Swank
« on: August 08 2012, 10:06:38 AM »
On my original plastic float switch for my alcohol system there was some kind of sealant on the threads.  I was told I wouldn't need it since the new float switch was brass and I was hooking it up to a brass line.
Should I use some kind of sealant on the threads?  And if so, what kind?  When I went to Lowe's and asked for a brass fittings sealant they just looked at me like I was crazy.
Re: Brass fitting sealant for alcohol tanks?
« Reply #1 on: August 08 2012, 10:11:37 AM »
if the fittings are npt, they should not need any, but, if you wish to use something, I would choose one of the liquid teflon sealants
Offline gordyzx9r
« Reply #2 on: August 08 2012, 10:15:11 AM »
NPT?
« Reply #3 on: August 08 2012, 10:21:05 AM »
NPT?
Normal Pipe thread, I think. A proper NPT connection shouldn't need sealant.
« Reply #4 on: August 08 2012, 10:30:48 AM »
NPT is a tapered, self sealing thread, but, a lot of this crap that is imported does not always seal without undue torque so a little sealant will aid in curing a potential problem
« Reply #5 on: August 09 2012, 08:20:58 AM »
national pipe thread/national coarse thread/national fine thread
« Reply #6 on: August 09 2012, 06:09:58 PM »
I thought it was National Pipe Tapered as opposed to National Pipe Straight.
Offline The Radius Kid
« Reply #8 on: August 11 2012, 02:19:18 AM »
Sealant would be a good idea.
You could get away without it,but there's always the chance........ ..
The primary purpose of thread sealant is not to seal,but to lubricate the threads so they engage deeper.
It's secondary purpose is to seal small gaps in the thread interface.
Read here:
http://tds.loctite.com/tds5/docs/567-EN.PDF
