Author Topic: Cooler install pictures  (Read 19993 times)
Re: Cooler install pictures
« Reply #15 on: August 07 2012, 10:16:15 AM »
I prefer the quick change set up using velcro
Offline 1KWIKSIX
« Reply #16 on: August 07 2012, 11:27:53 AM »
Each to his own!
This was the cleanest set up I had ever seen.......the custom laser cut powder coated bracket & mounting pieces and proper connecting line sets made it the "closest thing to a factory set up" that I've ever seen.
It was simply a bolt on installation.. .very well engineered & constructed.  Guess it depends on what you're looking for in a cooler set up.  I wanted a clean installation.. ...wanted to get rid of the insert fittings & hose barb set up used on my previous transmission cooler.  After dropping some CA$H into my transmission / torque converter, I wanted to make sure that I had a very good cooler.  Don't mind spending some money on a quality part.
After the installation, all I can say is that I was impressed with the quality of components used & would definitely recommend this kit to anyone considering an external transmission cooler.
Dave
« Reply #17 on: August 07 2012, 11:31:59 AM »
It's really a professional looking install :)
« Reply #18 on: August 07 2012, 11:39:31 AM »
The smallest B&M plate cooler that I would use is about $77.00 and I prefer the larger one that is about $93.  If you want to go the steel braided path, things can go up quick :)
Offline gnonyx
« Reply #19 on: August 07 2012, 11:58:33 AM »
Each to his own!
Dave
Hi Dave,
Please don't get me wrong, I'm not knocking the kit. The installation looks professionally done. If I had the money I too would have gotten the kit, but living on retirement one can put the extra cash on other visible things. Thanks for the photo, Julio
« Reply #20 on: August 07 2012, 01:47:43 PM »
Nice!  It will take an Earl Brown inspiration to top that! :041: :027:
Man, if you're going to Rube Goldberg something at least make it tacky. I'll stick with my "liberated" Adel clamps and one zip tie. (the oil cooler brace is a piece of metal that holds fresnel lens' in big screen TVs)
$280 looks like a powerlogger/PLX wideband and a $30 cooler to me.
« Last Edit: August 07 2012, 01:53:03 PM by earlbrown »
« Reply #21 on: August 07 2012, 01:52:01 PM »
How the hell do you delete a double post?
« Reply #22 on: August 07 2012, 01:53:44 PM »
Earl, how much labour to get to the point in you photos where the headerpanel is removed?
Guessing we'd then double that for a northern car.
« Reply #23 on: August 07 2012, 03:57:25 PM »
My header panel was removed because my car was stolen and destroyed. I knew I was going to do coolers and engine swaps so I didn't install it until last.
  When the oil cooler turned out to leak I popped it out without even removing the grille.
