Author Topic: Cooler install pictures  (Read 19992 times)
Offline dyermullet
« on: August 05 2012, 01:42:12 AM »
I need to install a trans cooler, and I am looking for pictures of other guys setups for ideas how to mount.  I am going to buy a bar and plate style cooler, and want to install it in front of my condenser.  I am not going to use the zip ties that go through the condensor so I am just looking for ideas for how to mount it.  I am thinking about making some kind of brackets maybe out of aluminum strap.
I should also add I have seen pictures of where guys have installed them under the car and under the battery tray and such.  I don't have a front mount and don't want to deal with wiring a fan right now, so I just want to put it up front.
Thanks
Re: Cooler install pictures
« Reply #1 on: August 05 2012, 09:52:53 AM »
Most I have seen were tied to the pair of cross bars in front of the condensor..zip ties, tie wraps, whatever they are called is the easiest way
« Reply #2 on: August 05 2012, 11:42:19 AM »
I have done this on all Trs I have owned.. If I can, I use 2 cable ties per corner, large, strong cable ties too. I haven't had one fail yet.
Offline dyermullet
« Reply #3 on: August 05 2012, 12:46:53 PM »
Ok I will go look at the car and see how that will work out.  Along that same track I found this where instead of zip ties someone used the rubber insulated clamps, I will look into that too.  http://turbobuick.com/forums/threads/installation-tips-on-a-hayden-1679-trans-cooler.374369/
I also found different variations of this:  http://www.turbobuicks.com/forums/attachments/transmission-section/30630d1201215963-trans-cooler-img_0172.jpg
My question about that is what is are they using with the two bolts to clamp onto the supports.   I might try to do something using that clamp arrangement, mount the cooler to the far PS to the core support itself and then use a clamp like that on just one end.
« Reply #4 on: August 05 2012, 01:02:27 PM »
There's a myriad of ways to attach them. I like the insulated clamp idea.
« Reply #5 on: August 05 2012, 01:45:28 PM »
Those clamps real name is "adel clamps"(actually it's  "MS21919 aircraft clamp" as Adel is a brand name ).  I'm sure you'd can get a huge bag off the internets for the same price as a local 5-pack.
Offline gnonyx
« Reply #6 on: August 05 2012, 02:29:40 PM »
It looks good!
I realized you are missing one of the support bars so I can understand why the vertical bar to support external tranny cooler.
I got a "U" shape clamp from Home Depot and installed the external tranny cooler on both support bars.
Offline gnonyx
« Reply #7 on: August 05 2012, 02:33:41 PM »
How did you hook up the external tranny coolers hose?
Wait something like this?
« Reply #8 on: August 05 2012, 03:23:31 PM »
I bought a few bags of the Ideal brand insulated clamps off of eBay very cheap.
Offline dyermullet
« Reply #9 on: August 05 2012, 09:36:47 PM »
It looks good!
Were they from the electrical section?
Offline dyermullet
« Reply #10 on: August 05 2012, 09:37:31 PM »
Thanks for the pictures everyone.  Now i have some ideas.
Offline gnonyx
« Reply #11 on: August 05 2012, 10:43:20 PM »
It looks good!
I believe they were in the garage door section and the "U" shape threaded ends are 10-24
Offline 1KWIKSIX
« Reply #12 on: August 07 2012, 08:16:47 AM »
Here's what I have installed. Bought it in a kit, comes complete with a powder coated mounting bracket & hardware + trick 5/16" reverse flare fittings on connecting hoses.
« Reply #13 on: August 07 2012, 08:49:43 AM »
Nice!  It will take an Earl Brown inspiration to top that! :041: :027:
Offline gnonyx
« Reply #14 on: August 07 2012, 10:11:24 AM »
I agree this kit is great, and it's made to be a plug and play type, and it should be if you're going to spend $280.00.
http://www.ebay.com/itm/Buick-Grand-National-Custom-Transmission-Cooler-Kit-/320851552093?pt=Motors_Car_Truck_Parts_Accessories&hash=item4ab43e275d&vxp=mtr
Personnally, my external tranny cooler, and the supported hardware cost was about $50.00, and that's for something that is out of sight.
