Author Topic: This is a new one...  (Read 4951 times)
« on: July 29 2012, 10:19:20 PM »
It wasn't even restricting my flow. I only lost 1 pound at idle (as read by my sealed liquid rail gauge, so it's within the SWAG)
I do believe I have my supra pump/hanger mods/ground mods sorted out!
Needless to say I still have some fine rust in my tank and now my fuel filter has a couple super magnets on the outside :)
Re: This is a new one...
« Reply #1 on: August 18 2012, 08:23:10 PM »
Eek.. What brand is that? Does that matter? :p
Offline 84 BuickGNYorkPA
  • PA Certified Machinist
« Reply #2 on: August 19 2012, 07:35:37 PM »
Hmm, I never cut my fuel filters open.... how did you manage not to create a spark? Look at that filter, there's got to be a better product on the market, no? Thanks for sharing!
Chuck
11.17@127.78
Offline Scott87
  • Boost Tube
« Reply #3 on: August 19 2012, 07:53:43 PM »
Could probably cut it with a can opener...  Or a pipe / tubing cutter...
Posted From Tapatalk
« Reply #4 on: August 19 2012, 07:55:49 PM »
I cut it open with tin snips. You can't use an abrasive to open up a filter as it defeats the purpose.
Not sure on the brand. It was a micro-guard or some house brand.
I have to give that filter credit. It started to collapse, didn't pass any unfiltered fuel and didn't choke off my fuel supply.
« Reply #5 on: August 19 2012, 10:15:52 PM »
On a lathe Chuck! C'mon :)
I like the pipe cutter- most safe
Offline Old Buzzard
  • Older than Woods!
« Reply #6 on: August 23 2012, 07:08:57 PM »
I use the Powerhouse filter cutter.... :cool;
Chuck
Injector inspector
Drag racing/hot rodding since 1955
USAF 67th Recon, Yokota AFB, Japan. 6594th Test Sqdn, Spfld, MA. The guys that brought you the Cuban missile fiasco in living b&w!
1960-1964
« Reply #7 on: August 23 2012, 08:15:44 PM »
I am glad you are older than me...when I wake up in the morning and my legs don't wanta work and it hurts to straighten up, I think of Chuck and elevate my aspirations to survive!   Everyone should have a filter cutter...more useful than a cigar cutter
« Reply #8 on: August 23 2012, 09:29:26 PM »
I think I should change the filter out now that I saw this thread, it's been a couple yrs already.
Chuck
11.17@127.78
« Reply #9 on: August 23 2012, 10:12:03 PM »
I would guess that most of us should
Offline Scott87
  • Boost Tube
« Reply #10 on: August 23 2012, 11:53:28 PM »
Did mine last summer when I installed my detchwerks fuel pump..  Figure only have about 6 to 7 k on the filter..
« Reply #11 on: December 10 2012, 01:45:28 AM »
Dropped the tank a few days ago to replace/inspect my pickup sock...
Turns out I had a SHITLOAD of rust sediment in the bottom, the pickup sock has to be clocked to clear the factory baffle, gas with rust flakes taste like shit AND has the benefit of being crunchy.
This expidetion started as my car was running out of gas way to early and I was having a hard time maintaining solid A/F ratios. Turns out my pump was installed so the pickup sock was hitting the plastic baffle and curling up. Damn thing could suck air with the tank 1/2 full.
Dremeled off the tit from the float level and reclocked the pump...     Right as I was about to put everything together I grabbed a paint stirring stick and did a depth measurement of the tank.
I transferred the paintstick to my pump hanger and was very surprised to find over 1/2" clearance from the bottom of the sock to the bottom of the tank(top of the baffle). How is it 2012 and I'm just now learning that GM handicapped my fuel system in this way? Surely to dog I'm not the first person to figure this out 26 years later???
  Granted I have a Supra pump, but I used the hangers factory stop location assUming it was in the right place. Boy was I wrong. Loosened off the clamps and lowered the pump so it just barely doesn't touch the tank and WOW what a difference!  Based on the tank dimensions that 1/2" of clearance is 1.82 gallons of gas I just couldn't reach.
When I dropped the tank my car was sputtering in the driveway running out of gas. While I had the tank out I siphoned 1.5 gallons out. I reinstalled the tank without the 1.5 gallons and had rock solid fuel pressure. (not to mention my pump is going to run cooler being submerged an extra 1/2")
How to cut the filter open with tin snips...   This time the media wasn't collapsed.
« Last Edit: December 10 2012, 01:50:52 AM by earlbrown »
« Reply #12 on: December 10 2012, 07:47:09 AM »
Just as a note the reason the pickup is not at the bottom of the tank was to stop from picking up water/moisture and sediment from there which used to be quite common in fuel sad to say. Which in return would cause other issues.
All the new pumps I have seen have filter systems now.
How many times when you were filling up have you seen someone drop the pump nozzle on the ground?
Mind you this was when these cars were dd.
AJ___
