Author Topic: Pulsator  (Read 18614 times)
Pulsator
« on: July 24 2012, 11:23:05 AM »
http://www.turbobuicks.com/forums/buick-v6-turbo-tech/54018-how-install-intank-fuel-pump.html
Im about to be doing a fuel pump upgrade, and I was jus curious as to why Earl removed the pulsator with just a rubber hose??  I plan to do this procedure step by step!!!!! :D
Re: Pulsator
« Reply #1 on: July 24 2012, 11:48:05 AM »
They are another point of failure, and even when working, are pretty useless. They come from the factory to reduce fuel pump noise - no need to keep it.
Re: Pulsator
« Reply #2 on: July 24 2012, 11:51:32 AM »
Thank you sir!!
Re: Pulsator
« Reply #3 on: July 24 2012, 01:30:31 PM »
new pump should come with a piece of high pressure f i hose
Re: Pulsator
« Reply #4 on: July 24 2012, 01:37:36 PM »
It'll be obvious when you get in there.
On that car it would hold fuel pressure for about 20 seconds; with the pulsator gone it would hold pressure overnight.  I also had to back off on the FPR and pull some WOT fuel just from tossing the pulsator.
While you're in there closely inspect the ground lug for the pump, the ground tab for the harness and make sure that tube that carries the ground has a strong solder connection where it passes through the mounting plate.
  If any of those are loose you need to break out the torch and soldier.
« Last Edit: July 24 2012, 01:47:50 PM by earlbrown »
Re: Pulsator
« Reply #5 on: July 24 2012, 03:30:34 PM »
'ten hut!
Re: Pulsator
« Reply #6 on: July 24 2012, 04:27:19 PM »
Heehee
Re: Pulsator
« Reply #7 on: July 24 2012, 04:37:27 PM »
Thanks!  My next question has been answered as I was going to ask if there is anything I should check for while it's down.  Let you all know when it's finished!!
Offline charleslong
Re: Pulsator
« Reply #8 on: August 03 2012, 06:38:39 PM »
Helping Phil swap out this fuel pump.  He had a Walbro 307 in the tank.  The fuel sock was dirty.  Also, the pulsator was already removed.  We about to re-install.
Re: Pulsator
« Reply #9 on: August 03 2012, 07:11:08 PM »
did you try to get rid of some of the trash in the tank?
Sorry, wendy, was not talking about you!  :D
Offline charleslong
Re: Pulsator
« Reply #10 on: August 03 2012, 07:55:26 PM »
It's a fairly new tank, and most of the trash that we seen was already clogging the old fuel sock. :D
Offline charleslong
Re: Pulsator
« Reply #11 on: August 03 2012, 07:57:38 PM »
Is there any reason that a walbro 307 was in there oppose to the 340?  What's the reviews on the 307?
Re: Pulsator
« Reply #12 on: August 03 2012, 10:37:07 PM »
it was what walbro sold before the 340 came out....if you bought one in the 80s or early 90's, that was what you got.  340 supposedly had a more efficient motor and a higher bypass pressure
Offline charleslong
Re: Pulsator
« Reply #13 on: August 03 2012, 11:17:11 PM »
Got everything installed.  After the pump change, the static FP increased to about 48 lbs.  He had it set to 42 lbs.  We took the car for a spin.  He floored it for a short pull.  02's where in the high 8's(842-850).  No knock though.  Got some more adjusting to do but so far he happy. :rock:
Re: Pulsator
« Reply #14 on: August 03 2012, 11:51:53 PM »
rich as that was, it's a wonder it did not show some rich knock....tune the wots down to no more than 800
