Nasty Wendy Isn't
Quote from: SuperSix on July 24 2012, 11:08:49 PM$144.72 @ Amazonhttp://www.amazon.com/ACDelco-88891017-Power-Antenna-Assembly/dp/B000S2PFTGRock Auto doesn't show that AC Delco PN.Odd looking RF cable?
Dave if Zap can use a coat hanger antenna why can't you
Quote from: ULYCYC on July 25 2012, 01:08:04 PMDave if Zap can use a coat hanger antenna why can't you We could go back to that P.O.S. windshield antenna where the station disappeared every you went around a corner.HEY! this is STEVE's Project. Can't you see we are all just HELPING
Maybe I could mount a flowervase in the hole in the fender
Having a motor rewound in the usa can be expensive. The oem units come from china and they get paid a eggroll a month.
In my case the motors weren't the issue it was always the cable inside that snapped. I think there are more issues of that than the actual motor burning up?
Quote from: Just a Six? on July 25 2012, 06:27:09 PMIn my case the motors weren't the issue it was always the cable inside that snapped. I think there are more issues of that than the actual motor burning up? This thread started with motor being burnt and no replacement, since you asked about the nylon cable then read this. I was lucky to repaired my nylon cable, but if the cable do snap again then I do the following TurboBuick member did as he replaced his TTA electric antenna nylon cable with 3/32 galvanized bare cable for less than $2.00. Sign into TurboBuick.com and paste this site:http://www.turbobuick.com/forums/threads/how-to-fix-your-broken-antenna-chord-for-less-than-2-and-never-break-again.369135/
Quote from: ULYCYC on July 25 2012, 10:26:07 AMHaving a motor rewound in the usa can be expensive. The oem units come from china and they get paid a eggroll a month. Many, Many, Many years ago when I finished and left the USMC I worked in a electric motor shop in Long Island NY. I still keep contact of the owner and I will ask him about these little electric antenna motor. The worst he could said it will be expensive to rewind, but then again what is the cost of rewind against a new one that still has to be modify to fit. Anyone has any ideas of what type of compatible cars that uses the electric antenna to the TR? I'm not talking about the antenna itself, maybe do a motor switch.
