Author Topic: Not One of my Better Weeks  (Read 7086 times)
« on: July 22 2012, 05:48:01 PM »
So I was out spraying mesquite last week end and realized I had more diesel and poison on me than I was getting on the trees...spray wand decided to start leaking like mad.  Gave it up and came home and ordered a new sprayer wand and some new hose to go with it.
Then I noticed not much air was coming out of the 25000 btu window unit I have mounted in the wall.  Pulled the front off and saw it was frozen up.  Turned it down and it worked better, but is still freezing up and not lasting long enuf to get the house below 80 most the time.
Got tired of trying to get my ten year old, little used weedeater to keep running after it starts...acts like an air leak but fuel lines and bulb look good so I assume it must have a hardened diaphragm or a crack in it...rationali zed I should just go spend $250 on a new one instead of trying to install a ten buck carb kit in this one....somethi ng about my fifth childhood, I think.
Got in my truck to take the girl who cleans my house home and noticed a warning lite.  I thought everything was reading okay so I figured I would wait til Thursday to look at it.  I forgot.  Then Thursday afternoon, I jumped in it to go to Angelo to look at weed eaters and air conditioners plus have dinner with my friend.  Got a mile down the road and notice the oil pressure gauge was below L.  Was not making noise and figured it was just way low on oil as mysteriously happens every once in awhile.
Was pissed, went home, jumped in a Buick.  Figured I could at least get a weed eater.  It was low on gas so I had to stop for gas and was running late.  Called my friend and told her I would be late.  Went and bought a weed eater that I had spent the week researching.  Box was about six and a half ft long and would not fit the Buick.  Stuffed it thru the window and went to eat.  While waiting on my friend, I got pissed because I noticed the buick was getting hot idling.  That made me determined to get the weed eater in the car and roll the window up so it would not get stolen in parking lot.  Took it out of the box and got it in the car...then I started jumping up and down on the box until it crumpled to my will (and size 12 feet) and decided to allow me to bend a couple of feet over and stuff it in the car.
On Friday, I put a couple of quarts of oil in the truck, fired it up and the oil gauge went back to where it always reads.  got into town to eat and noticed the needle had fallen way back.  Oil was still low.  Went to the station and bought some more oil, put it in, and the gauge went right up again.  Got a block and it started dropping.  By the time I was home, it was below L again.
Started reading Craigslist and such for a replacement truck.
On Friday afternoon, I put the weed eater together, cranked it up and it immediately snapped the lines off when it hit some tall grass.  Pulled the spool off, refed the line and tried it again.  Worked like a charm!  No more problems.  Not unless you consider snagging the phone line behind the house and ripping the line out of the wall and out of the box, a problem.  Almost made me wish I had stapled that line back up when it came loose.
Decided to try the truck again.  Drove it to the back of my place to turn the windmill off.  Needle dropped down about a quarter inch below the L by the time I got home.
Ordered a thermostat for the Buick.
Yesterday, I started searching seriously for a replacement truck while bitching about not being able to afford one.  In the afternoon, I began to wonder why I never heard a rattle out of the engine which made me wonder about the sender.
Got into the other Buick and drove it to Brady to Napa.  It was closed.  Went to an O'Reilly and they had one.  Realized the Buick was also getting hot in town and it was also on fumes.  Start pumping gas when it dawned on me that it was low because I wanted to run it low to put a new fuel pump in it.  Stopped pumping.
Got home, got in the truck and drove it in the yard to my shop.  Noticed that the oil pressure was holding steady.  Revved the engine and the needle stayed where it should. Began to irritate me.  Crawled under it to change the sending unit...no way Jose.  Need a different wrench and/or pull the filter.  Banged it a few times for good measure.
Cranked it up, normal oil pressure.  Let it idle 30 minutes and revved it now and then...good oil pressure and no noises out of the engine other than its usual misfires and popping.
Came in the house, told my friends to cancel the search for a new truck for the moment.
Ordered another thermostat for this Buick.
Went back out and put the new wand on my sprayer...no leaks...wind blew the spray back on me and I smelled like diesel...
Today, it's 106 and I wish I had a new AC and two strong guys to get it 8 ft up in the air to  replace this pos!
Re: Not One of my Better Weeks
« Reply #1 on: July 22 2012, 06:02:11 PM »
Oh, yeah, I was supposed to go to the dentist on Tuesday because I had a toothache and the dentist thought I needed a root canal and was going to xray it to be sure.  Wind storm came thru and blew the roof off the building next door and knocked a hole in the dentist's roof...did not want to drive to his other office in Brady so I cancelled that one
« Reply #2 on: July 22 2012, 06:23:22 PM »
Better days ahead :atbeer:
« Reply #3 on: July 22 2012, 06:25:59 PM »
yeah, I just ate a quart of ice cream!
Offline The Radius Kid
« Reply #4 on: July 22 2012, 09:40:57 PM »
That'll work ........ or a beer or two. :chin:
« Reply #5 on: July 22 2012, 09:52:39 PM »
Beer float?  :icon_neutral:
« Reply #6 on: July 22 2012, 11:03:44 PM »
Steve, did you catch the post I made a while back about the Oreilly's commercial discount?
« Reply #7 on: July 22 2012, 11:25:26 PM »
yeah, but, I always forget.  this was 8 bux so I guess my senility did not cost too much
« Reply #8 on: July 23 2012, 12:37:30 AM »
Good thing the challenger isn't done - you might have had to walk home ;)
You could just come up north and help me finish installing this nitrous kit  :player:
Offline Grumpy
« Reply #9 on: July 23 2012, 07:20:19 AM »
Dammmm.. I thought I was the only one this happened to.. Right now I have Melissa's GN using it as our daily driver.. All my other junk is broke or "loaned out"  :rolleyes;
« Reply #10 on: July 23 2012, 08:14:26 AM »
Amazing how 3 out of 5 cars can be mort at the same time?
No remote filter on the truck? 2WD?
« Reply #11 on: July 23 2012, 09:20:35 AM »
4wd, Dave and no remote oil filter unless you call its location remote...I need to get the Challenger down out of the air and install the instrument cluster I made-then rewired the electric seat and install the new carpet I bought last summer.
Probably the best car I have is the Camaro that I ripped the wiring and brakes out of three years ago and have not touched since.
Jeremy, even my friend Steve Yaklin has bought a hopped up 2009 Challenger so I think Buicks are passe these days...he still has two but wants to sell one of them I think.
Dan, they are right, stuff happens!  :)
« Reply #12 on: July 23 2012, 09:48:06 AM »
Mine is under the bumper. '98. Been a sh*tty year for keepn' stuff running...
« Reply #13 on: July 23 2012, 09:51:40 AM »
Mine is on the block....'97
« Reply #14 on: July 23 2012, 10:18:32 AM »
And here I was feeling a little down after Natasha's Camaro got run over by a dump truck a week back? That is more of an inconvenience, where Steve's story is adversity.
Hang in there buddy... a hill usually has two sides. ;)
