Author Topic: Running lean. PL review  (Read 7947 times)
Offline LeeRoy
Re: Running lean. PL review
« Reply #15 on: August 04 2012, 10:01:13 PM »
Thanks for the help. I set the afr to 11.5 and runs much better.
I'll start increasing the boost to get some more power to the gnd.  :icon_lol:
« Reply #16 on: August 04 2012, 10:29:04 PM »
yes, but when you add boost, it will obviously run leaner...so I was suggesting you leave it rich and let the boost bring you into line
Offline LeeRoy
« Reply #17 on: August 04 2012, 10:49:03 PM »
The programmed closed loop AFR is 11.5. If I add boost why would this change?
The chip is supposed to add fuel to keep 11.5 constant.
« Reply #18 on: August 04 2012, 10:58:04 PM »
You are right...I forgot it was in closed loop...but, still, when the boost gets to 20 psi, I would set something closer to 11-1 to give myself a margin for error until I found what  I can run for a given boost
I believe in caution before a new engine :D
Offline LeeRoy
« Reply #19 on: August 04 2012, 11:13:24 PM »
Thanks. I'll take your advice and back down to 11.1.
