Author Topic: Stock AXCA chip  (Read 2135 times)
Stock AXCA chip
« on: July 18 2012, 01:26:51 PM »
I don't see why the stock chip on a stock car get such a bad knock, I suspect things get exaggerated over time?
Once the rod gets shortened and boost cranked  I will believe it has no/little margin.
But if you have a scan tool and see no knock with whatever octane you have available it it so bad?
Flame away :)
Re: Stock AXCA chip
« Reply #1 on: July 18 2012, 01:49:57 PM »
Without writing a novel the stock chip has 22-23 degs of timing.   This was designed for 12-14lbs of boost with better pump gas circ. 1987.   If you lower your boost below this I guess you can still use it without knock.
Re: Stock AXCA chip
« Reply #2 on: July 18 2012, 02:00:02 PM »
but it will not idle as smoothly nor drive as well
