Author Topic: NA Cranks  (Read 2729 times)
NA Cranks
« on: July 17 2012, 01:46:36 PM »
So what happens if you run an NA crank- say sub 400HP?
Other than the Radius any other differences?
Re: NA Cranks
« Reply #1 on: July 17 2012, 02:38:59 PM »
should be fine, imo
Re: NA Cranks
« Reply #2 on: July 17 2012, 03:28:17 PM »
what would be the limits on a NA crank?
Re: NA Cranks
« Reply #3 on: July 17 2012, 03:44:56 PM »
I have seen them in the upper elevens.
the problem with all the cranks these days is the number of cycles and abuse that they have undergone.  If the crank is low mileage, then it should be a lot stronger with regard to future life than one that has 150,000 miles of hard running...
It may be that a standard crank (NA crank) is actually in better condition with regard to metal fatigue that a turbo crank that has been hammered on for years
Re: NA Cranks
« Reply #4 on: July 17 2012, 03:46:24 PM »
Didn't Banning run high 10's with a 40 over block and NA crank?   I know many over the years who ran 11's and low 12's with it.  Not my choice to do it.
Re: NA Cranks
« Reply #5 on: July 17 2012, 06:01:19 PM »
He sure did! I know that a few posts mentioned this about his engine.
Altho, I guess like any parts the Tuning plays a big role in the 10's
