The Bastard Child Buick Board
hopefully it is not the chain, but they sound different when they jump a few teeth.We will figure it out when you get back. It will be worth it when all is sorted out and you can just drive the car and start kicking azzz
it will be obvious...but we can check a few things first, starting with spark
Timing setcamshaft thrust buttontiming chain tensionerTiming cover gasket set with rubber front sealit's all available from Rock Auto...or most other places
should we assume it had spark because you did not mention the result of the test your brother was going to do....unless I missed it
When I stripped my timing set I lost spark.
