follow my instructions and remember to hold the pedal on the floor...discon nect the orange wire or the cam sensor so it won't try to start...or leave the cam sensor cap offCrank the engine until the needle stops rising...this will take a few seconds of crankingAn engine in good condition will make 145 psi or soLet us know what yours reads
For it to be a professional opinion I'd have to charge .. ...And nothing makes me shudder more than a "freshly rebuilt engine" on these cars.I'd be on stage four by now:1) irritation2) drinking hoping that will bring me an answer other thna pulling the timing cover/oil pan3) checking lobe lift hoping I can find an answer (and hoping that answer isn't a flat lobe)4) Pulling the timing cover and oil pan
The site that Steve gave you on how to replace the timing chain replacement; on #4 it saids "remove the harmonic balancer bolt, (hope you have a air gun)". If you don't have an air gun you can use a DeWalt DW059 1/2" 18V Cordless Impact Wrench. You will also need a 1 1/8" socket, Advanced Auto has them for around $10.00, that's what I used when did this work. Just don't use the cordless impact wrench to put the harmonic balancer bolt back in place or to use it to tighten the harmonic balancer bolt.
another http://www.gnttype.org/techarea/engine/tchain.html
