Author Topic: Pending....  (Read 71057 times)
Re: Pending....
« Reply #180 on: August 25 2012, 04:11:19 PM »
better view of pulley
Offline gbsean
Re: Pending....
« Reply #181 on: August 25 2012, 04:19:47 PM »
that plate should unbolt...thats what was holding the intercooler fan ....the Crank bolt is behind that...
Re: Pending....
« Reply #182 on: August 25 2012, 04:21:40 PM »
thats wat i was thinking.  Any clue on how efficient that fan is?
Re: Pending....
« Reply #183 on: August 25 2012, 04:29:44 PM »
Most of the fans have broken blades by now and have been removed....but, once the bolts are out, I would suspect rust is holding it to the pulley
As there was no shroud, I kinda doubt they were very efficient
Re: Pending....
« Reply #184 on: August 25 2012, 04:32:01 PM »
ok.thanks
Re: Pending....
« Reply #185 on: August 26 2012, 01:20:56 PM »
Got the compression tester, and im only pulling the number one plug.  What should the gauge read while turning over?  Thanks
Re: Pending....
« Reply #186 on: August 26 2012, 01:58:06 PM »
follow my instructions and remember to hold the pedal on the floor...discon nect the orange wire or the cam sensor so it won't try to start...or leave the cam sensor cap off
Crank the engine until the needle stops rising...this will take a few seconds of cranking
An engine in good condition will make 145 psi or so
Let us know what yours reads
Re: Pending....
« Reply #187 on: August 26 2012, 02:06:20 PM »
Thanks Steve
Re: Pending....
« Reply #188 on: August 26 2012, 02:17:37 PM »
and i leave the other plugs in? initially you said to remove them all.  But now im just taking the number one out?  sorry for sounding slow.  I actually am slow and a bit annoyed.
Re: Pending....
« Reply #189 on: August 26 2012, 02:18:35 PM »
and i meant to ask what all it took to remove that oil adapter plate for the oil cooler?
Re: Pending....
« Reply #190 on: August 26 2012, 02:26:45 PM »
nevermind. think i found it on vortex.  i didnt see a way to loop the hoses which is why i asked.  I would prefer to loop the hoses  because i think it would be easier.
Re: Pending....
« Reply #191 on: August 26 2012, 02:34:38 PM »
 said one plug because I thought it was easier and good enough for this purpose
Re: Pending....
« Reply #192 on: August 26 2012, 02:35:15 PM »
cool
Re: Pending....
« Reply #193 on: August 26 2012, 03:18:23 PM »
....but when running a compression test the correct way, you remove all the spark plugs, take the readings, and write them down with a mileage notation.
Might save a lot of time with future troubleshootin g.
(plus the engine spins over better with no plugs in place)
Re: Pending....
« Reply #194 on: August 26 2012, 03:35:50 PM »
ok. that makes sense. thanks earl
