Zap *STILL* wears Depends
progress so far
Only potential good news is that i got the Radiator dropped off. Guy told me to call him monday.
been too long since I had a fan on the pulley. Don't recall if there is anything blocking you from sticking an extension into the center of the pulley and down to crankshaft bolt or not-pictures I gave you from the manual show three bolts holding the pulley I thinkto do a compression test, you turn the engine over with the starter.Remove the spark plugs, screw the compression gauge into one of the plug holes, then put the gas pedal to the floor and spin the engine over with the key. Unplug the cam sensor before you turn the key over...or, unplug the the orange wire off the battery so the car will not be trying to makes sparks during this process.Me, if I am doing this test for this purpose, I might only take the number one plug out because it will spin fast enuf if the battery is charged. Let it turn over about six or seven times to get the full compression reading. Be sure you are holding the gas pedal down
