Zap *STILL* wears Depends
Tme is my biggest enemy right now. Might have to send car to the shop.
Quote from: phil_long on August 21 2012, 01:27:14 PMTme is my biggest enemy right now. Might have to send car to the shop. May be cheaper to fly Steve in and get a few cases of PBR!
There is a reason why I tell everyone they need to own two of these things!
Hi Phil, I have been reading on all of your threads and I know how it feels to be threaded of the unknown. This site and as well as TurboBuick.com has great mentors who can help and guide you through replacing timing chain, both sprockets, damper tensioner, cam button, and front seal if that's what is needs to done. When I did this job I read, ask many, many questions, and a must have; PATIENCE. The other option is to see if other members in this board and/or in TurboBuick.com board, who lives near your area of St. Louis Mo. Maybe someone might be able to assist you in your repair.
I told you to rotate the crank slowly and to watch the cam sensor window wheel to see it it turned smoothly with the crank or if it hesitated at times and then started turning again.Also, if the compression is low, then that is a sign
Unfortunately Phil, that's the natural of these cars, one don't know until you dive in and examine the outcome. I don't know your car profile since there is nothing written in your Sig section. Many TR owners have replaced the timing components and mostly the cam nylon sprocket. Some even replaced the nylon cam sprocket as early as 20,000 miles, since it's possible for sprocket teeth's to break off for many reason (stress, heat, age, etcs), and then do major damage to the engine. As Steve mention before remove the timing cam cap, have someone turn the engine over and closely, and carefully look at the cam disk window and see if it turns smoothly or does it hesitate as it turns. I saw your video, but that doesn't prove if the timing has jumped, or some of the cam sprocket teeth are missing, or broken off. When I replaced the timing components, I found one tooth broken off and that's one too many. This type of work may look intimated, but you need to slowly take baby steps and when it doubt ask questions. I know many mentor members on board are here to help others, especially SuperSix, Steve, PacecarTA, and many others.
