Author Topic: dash problems  (Read 3046 times)
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
dash problems
« on: July 15 2012, 08:42:50 PM »
the last two times i drove my car i have a ticking sound in my dash. sounds like a relay going on and off. the light for my boost gauge is blinking in sequence with the ticking. any ideas what this is?    :chin:
Re: dash problems
« Reply #1 on: July 15 2012, 08:52:25 PM »
speedo cable
Re: dash problems
« Reply #2 on: July 15 2012, 09:32:54 PM »
Does your car have the line of led's for a tach?
I would agree speedometer, but, ?
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
Re: dash problems
« Reply #3 on: July 15 2012, 11:14:46 PM »
its not the speedo cable it has its own noise lol, yes it is the line of leds,
Offline TurboCajun
  • Keith Theriot
  • 6 Packed
Re: dash problems
« Reply #4 on: July 17 2012, 08:31:21 AM »
found it, its the alky controller box, must be a relay inside of it. doesnt have the clicking with ignition on engine not running. only with engine running that the clicking starts. when i touch the gas pedal it starts clicking. any Ideas? i have check all my connections
Re: dash problems
« Reply #5 on: July 17 2012, 09:01:48 AM »
I would ask Julio.
Sounds like something is clicking when the vacuum that it is sensing changes
