Author Topic: Fuel Pressure Gauges  (Read 8531 times)
« on: July 15 2012, 04:57:12 PM »
I am always ranting about rail mounted fuel pressure gauges being useless, and, often inaccurate.  Here is a case in point.
I was talking to Ed yesterday and he mentioned someone brought a Regal by that was running badly.  Guy had just purchased a new rail mounted gauge for more than $30, installed it, and adjusted the pressure to 43 psi.  Car ran badly.
Ed put his OTC gauge on the car and found the fuel pressure was 28 psi and not the 43 the gauge was showing.  Readjusted the pressure and the car ran properly.
My experience is that even if they read close to right initially, they eventually start reading wrong with age and vibration-liquid filled, or not.
If one goes to Grainger, or similar, the good quality, low tolerance gauges usually sell for more than $100 for a bare gauge.
Further, if one thinks about it, a rail mounted gauge does absolutely nothing for tuning.  If you want to adjust your fuel pressure, the O2s and the BLM's will give you all the guidance you need to set the idle.  You don't need a gauge to do that.
The principle thing a gauge is good for is to monitor fuel pressure at boost to insure the two are in lockstep.  If one is running on straight gas, the O2s will show you when there is a major drop off, but, if one is running alky, it may not be as obvious.  Also, monitoring wot pressure will often allow you to catch a problem when it is still small in magnitude which O2s do not yet reflect, or which is being covered up with alky.    This requires a gauge that can be read while driving.  Having a gauge on the rail is only good for impressing the kids down at the Sonic, or the Wawa.
Take that $30 and go buy a lap dance.  It will do more for you.
Re: Fuel Pressure Gauges
« Reply #1 on: July 15 2012, 11:39:19 PM »
Nice
Offline smokin-6
  • 87 T
« Reply #2 on: July 16 2012, 07:35:22 AM »
 :rofl:
87 T Ported stock heads, 212/212 roller, stock block, ALKY, CAS V4, 6262, 3.5 MAF & Translator, new tranny w/ 9-11
Original owner
« Reply #3 on: July 16 2012, 09:19:32 AM »
Or use that $30 to buy Phil a bus ticket because he knows how to set it without a gauge!
« Reply #4 on: July 16 2012, 01:00:05 PM »
That's right.  Im officially a step higher than a noob!! :rock:
« Reply #5 on: July 16 2012, 03:05:17 PM »
much as we beat you up, you are too well used to be a noob!
« Reply #6 on: July 16 2012, 03:47:28 PM »
This is true
Offline Scott87
  • Boost Tube
« Reply #7 on: July 16 2012, 04:29:00 PM »
Any chance you have a model number you could suggest?
Posted From Tapatalk
« Reply #8 on: July 16 2012, 06:03:41 PM »
Mcmaster.com  3795K16
subject to approval :)
- gasoline rated, glycerine filled, four inch, ss case,  two percent mid scale
« Reply #9 on: July 16 2012, 09:02:49 PM »
any idea whats the widest tires I can fit on my stock rims?
« Reply #10 on: July 16 2012, 09:22:53 PM »
LOL  I think some have run 275s with rolled fender lips...but seems to me that would be a bit squirrelly
« Reply #11 on: July 16 2012, 09:43:55 PM »
I'm sure you can fit  those 275's weaselly.
« Reply #12 on: July 16 2012, 10:38:03 PM »
Whats the biggest turbo I can run and how much boost will it push?
« Reply #13 on: July 16 2012, 10:42:15 PM »
Do you want to run a hood?  How many times do you wish to push the boost?
« Reply #14 on: July 16 2012, 10:48:31 PM »
I want the biggest turbo I can fit. I want it to work with true duels and gears.
I saw some hedders on ebay too that look pretty sweet.
