Have these old items for sale still:
2 Bar MAP Sensor
Air Filter
Air Filter Housing
AM/FM Cassette Player
Ash Tray
ATR Billet Oil Filler Tube
ATR Black Beauty 8mm Plug Wires
ATR Pitbull Chip
Casper's Tach Tap Mating
Casper's VDO Converter
Charcoal Canister Bracket
Chip
Crankshaft Sensor (Recall)
Downpipe Shield
Fuel Injectors
Fuel Pressure Regulator
IAC
Jack
Kirban Brake Dust Shield (4)
Oil Pressure Sender
PCV
Plug Wires
Quick Spool Controller
Radiator Cap
Radiator Overflow Tank
Rear License Plate Bracket
Rear Speaker Hangars (Pair)
Rearview Mirror
Red's Volt Booster
Starter
Stewart Warner 10K RPM Tach
TPS
Vacuum Block
Water Temp Sender
Windshield Washer Fluid Tank
In addition to those items I also have:
TA-49: 8 years old, 3K miles, & I was told it is leaking.
Stock heads: Off of my GN with 80K miles, I replaced them with Champion Irons.
Stock heads: Off of my T-Type, I'm told they were leaking past the valves.
Poston fuel pump wiring upgrade, I do not have the instructions.
Stock front cover, I replaced mine with a piece by Earl Brown.
4 Turbo Tweak Chips
