Remove the iac. Spray it off with brake/carb clean. Spray the cleaner into the iac passage in the throttlebody thru the iac opening and thru the passages in the throttlebody.. .see first pic http://www.vortexbuicks-etc.com/throttle_body.htm get the black crud out if presentcheck ALL (including the small hard plastic lines) the vacuum hoses for leaks as well as clean out the pcv...Make sure the plunger is free to move when you shake the pcv, Put tie wraps on all the lines at the vacuum lines at the vacuum block, etc to keep them from blowing off under boost.make sure there is no leak(s) between maf and turbo.Make sure there is no leak around the base of the plenum.Crank the car up, let it warm up while watching the iac's in park...AC off....numbers should start fairly high and come down to 10-30 as the engine warms up. Adjust as required.Check the engine vacuum when warm and in Park...should be around 17+ on stock cam and very steady...if the cam is not stock, it could be down around 14 or so...still pretty steadyIf the car feels like it has a miss, remove one injector connector at a time and see if the rpm drops a bit, or misses more, each time one is removed. Note any cylinders that don't drop or cause a miss
I always love it when people post that their car is not running right; then post later that it is running better and don't bother what they found wrong!
Nice when they run right and you can begin to enjoy driving them
