Nasty Wendy Isn't
What is the intent behind the Wildwood manual proportioning valve to adjust the brake bias? What does that mean exactly?
In the trunk, I have to be honest...I don't think I've ever looked under my carpet in the GN. Are they all like that or does this T-Type have an access panel to the top of the gas tank to get to the fuel pump?
Is that an RJC boost controller? You can see it in one of the engine bay pics I think in the 2nd or 3rd post.
That adjusts the amount of brake line pressure on the line it's attached to. If you have aftermarket brakes, you can adjust the line pressure, so one set (frt/rear) doesn't lock up before the other set.
No, that isn't for fuel pump access - not sure what it is exactly for, but I know it's not a FP access door.
I am 99% sure it is.
Those are the intrepid fans.
That bolt through the steering shaft looks wrong.. Maybe he put it in there in addition to the factory bolt as a failsafe.
Is that a power steering leak? Or are the AN lines he used for the trans cooler leaking? It's on the wrong side for a PS leak.. Oh - trans lines going into the radiator are leaking...
Whoever owned that car took damn good care of it....
Quote What is the intent behind the Wildwood manual proportioning valve to adjust the brake bias? What does that mean exactly? I installed one like that on my GN when I did the S-10 rear wheel cylinders. By cranking down the pressure on the valve you can increase the pressure to the rear brakes.
Quote from: SuperSix on July 11 2012, 01:52:03 PMThat adjusts the amount of brake line pressure on the line it's attached to. If you have aftermarket brakes, you can adjust the line pressure, so one set (frt/rear) doesn't lock up before the other set.The brakes are stock. SS brake lines is the only real change that was made in addition to that Wildwood device.QuoteNo, that isn't for fuel pump access - not sure what it is exactly for, but I know it's not a FP access door. Are all TRs like that?QuoteI am 99% sure it is.I have one in the box still somewhere that I decided not to use on the GN, I'll match it up. QuoteThose are the intrepid fans.Awesome, so they should fail anyday then...I have a spare, no kidding. I have a brand new in the box set of fans that I installed the racetronix kit on but after reading how they failed I went with the dual spals and casper wiring harness on the GN.QuoteThat bolt through the steering shaft looks wrong.. Maybe he put it in there in addition to the factory bolt as a failsafe.That I believe is the ever popular tb.com Jeep Grand Cherokee (?) mod for to fix the play in the steering...I think.QuoteIs that a power steering leak? Or are the AN lines he used for the trans cooler leaking? It's on the wrong side for a PS leak.. Oh - trans lines going into the radiator are leaking...Yeah...that should be an easy fix.QuoteWhoever owned that car took damn good care of it....I have no idea, my friend basically bought it as a stock TR (with stock wheels and all) and he wanted to make it go fast so all of the mods are basically what he did in the past two years.
Which is good for drag racing (if you don't jump on the brakes at the finish line)
If the bill is from SE Turbo I guess you take the $amount with a grain of salt...
